It comes from the demo showing the Adam vs the DC-5 and how much hum they each induce in a Wah pedal.
The DC-5 induces less as it has a torroidal transformer that better contains its electromagnetic field.
Both supply clean, isolated 9v power which is not itself noise-inducing.
Most folk don't realise that if you put a venerable Voodo Lab Pedal Power 2+ under a wah you get unbearable noise too. It's a thing. The DC-5 is simply very well engineered to reduce it, so if you have a wah mounted nearby it's a good option.
The Adam is not noisy (unless a PP2+ is)
I haven't tried it personally but I'm going to as mine currently sits on the top.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
