Who could oil a strat neck for me?
LebarqueLebarque Frets: 3898
I've got a lovely roasted maple strat neck that I've been playing raw, but I want to give it a thin finish. Don't want sticky nitro, so thinking about oil. Tru oil? Tung oil? I don't want to change the colour and I'd like a slight sheen, rather than shiny gloss finish. Any advice and could anyone do this for me? Cheers.
  • It's an easy technique - worth having a go yourself for education and maintenance purposes :)
  • mbembe Frets: 1840
    edited August 2017
    I've used Tru-Oil and it is very easy to apply using a clean white rag or even kitchen roll. I did find it a long drawn out process that demands patience.  It needs a couple of days for each coat to fully dry and then a light rub with 0000 wire wool to bring it back to a satiny matt ready for the next coat.
    You can get away with just a couple of coats on Maple. Mahogany seems to soak it up so I think it needs a minimum of 5 coats.
    The feel of a Tru-Oiled neck is very slick compared to Nitro. It's not really an oil as such, it's more like a rubbing varnish.
  • John_AJohn_A Frets: 3775
    Danish oil, true oil or Wudtone are all a piece of cake to apply.
  • TeyeplayerTeyeplayer Frets: 3257
    +1 for tru oil and having a go at doing it yourself -you'll be glad you did.
  • It's not hard, I've done it myself with tru oil and wax following the Music Man method
  • sawyersawyer Frets: 732
    Dead easy man,have a go yourself. It's be nearly impossible to get it wrong.
  • jellybellyjellybelly Frets: 762
    You'll need:
    tru oil
    lint free cloth
    30 mins a day for a week
    Dead easy!!
  • DavusPGDavusPG Frets: 451
    +1 On the advice for doing it yourself but I thought oil finishes on mahogany was a no go?
  • LozboyLozboy Frets: 80
    I have used  Tru-Oil on a maple neck and also  to touch up areas with alot of success.It is easy to use/sand and clean up afterwards.Good luck with it.
    I have a couple of Charvel Desolation models that both came with a very dry, allegedly oiled finish to the mahogany necks. I have since Tru-Oiled both of them and now they are silky smooth.
    Tru-Oil won't fill all the grain in mahogany unless you wet sand with 1000 grade abrasive paper and allow some of the resulting slurry to fill the pores.
  • WezVWezV Frets: 16757
    The problem with mahogany is it takes a bit more work, but still possible.  Either re-oil when it dries out or wet sand with the oil to develop it quicker.   The more you do it, the less it will need.
    If you want to keep it easy just wipe on, leave 5 minutes and buff off.  Rinse and repeat.   It only takes a lot of time if you are trying to build it up
    @mbe & @WezV ;
    Thanks for the info....so a Les Paul with an oiled neck isn't an impossibility then?!
    Its never as stable as maple, but if you know the neck is stable anyway it should be fine.  Its a definite possibility but i would lean to tru-oil over danish for this reason
    I wouldn't recommend oiled mahogany for a world tour, as it will often be more affected by environmental fluctuations.
  • LebarqueLebarque Frets: 3898
    Thanks all. Any good tutorials / youtube vids I'm how to do it? Where can I buy tru oil and how do you get it off the frets afterwards etc?
    Cheers
    There is a useful post in the useful posts section of making and modding.  It's my version, which is more labour intensive but gives the sleekest feel and doesn't take as long as some of the methods mentioned here.
    used to be specialist gun shops only for tru-oil.  Now you will find it all over the place.  Google is your friend
    if you buff the oil off a few minutes after applying you won't need to worry about build up on the frets
  • NPPNPP Frets: 236
    edited August 2017
    I followed @WezV's method with my Strat body (and did the neck as well because why not) and it really does work very well and I was more or less a complete novice. I subsequently applied the method to a beech kitchen worktop I had bought to use as a desk and found that even if you rush things a bit, with fewer coats and shorter drying times, you'll still get a nice and durable finish.
    Thanks, I'll take a look
