Vintage TS808 vs TS9
  • robinbowesrobinbowes Frets: 3052
    I went looking for info about the original OD-1 and found this range of chinese clones:
    http://www.valeton.net/html/en/index.php?ac=article&at=list&tid=21
    They look quite interesting.
    Hang on, I don't do pedals any more - I have an Helix-  gaaah...
  • Dave_McDave_Mc Frets: 2362
    I really like the CM2, but I'm not sure it's what I'd get if I wanted to really nail the TS thing- it's got a bit more headroom and less compression than a TS (I guess maybe because of the bumped-up voltage inside the pedal?). It's an awesome pedal if you want one OD to do everything, and getting 90-95% of the way to a TS is close enough- but if your main aim is a TS there are other pedals that do it better IMO.
  • JEPBLEPJEPBLEP Frets: 188
    I suppose the biggest challenge is to ensure things are "stackable" or don't get into each other's territory too much. Although I'm wary they're all trying to do a similar thing, just in different ways. The TS will live on a board with a KOT and potentially a dedicated clean boost, such as a Timmy or something. I'm still tempted by a Klon Centaur because of the shinyness, but everyone seems in violent agreement they're too much.
  • TimmyOTimmyO Frets: 7543
    edited August 2017
    imho a clean boost, a TS and a KOT is already overlapping.
    It'd be worth trying some differently voiced drives - maybe something JFET based like a Blues Driver or an OD-3, or something a bit harder clipping like a RAT (and if you like mojo then tracking down an original RAT with the 'correct' chip etc is a thing)
    Red ones are better.
    I bow to your knowledge -as you know-, but I thought the KOT was Bluesbreaker-based and pretty stackable with a TS? I understand the clean boost may be superfluous with the yellow side of the KOT set to boost, that's a good point.
    From what I can gather, the RAT is more "fuzzy"? Must... do... more... research...
    Just an example of something that isn't using opamp+diode clipping. There are so many cool things out there.
    to be fair an actual TS/clone thereof is a very useful thing to have - good at pushing a good valve amp (like yours) into 'more is better' territory.
