Withdrawn - Which boutique amp head?
CastroCastro Frets: 512
edited September 2017 in Amps
 I'm in the nice position of being able to purchase an amp head and cabinet up to about £3,000. It will be my last amp purchase - just turned 56 so it's a birthday pre-retirement investment.
I have 3 on my shopping list and would love some opinions and feedback.
I play mainly clean with pedals for dirt. I play in small pubs in a 3 piece with a bass player and a drummer....we're not loud and play all Original stuff in different genres but no metal.
Currently have a Two Rock Crystal 40w combo that does great cleans but it's heavy thus the move to lighter items.
I like the Two Rock Studio Pro 35 head which I tried at Coda. The Swart ST45 is an alternative and also Morgan RCA35.
Thoughts?
  • For me it would be a Lazy J80 as head and cab or a combo if you want reverb built in but that's heAvy.  You could go the j40 with a 2x12 cab.
  • KalimnaKalimna Frets: 1542
    Speak to Cliff Brown at 633 Engineering - boutique in the proper sense of the word, beautiful amps and customisable to your own requirements. Plus it keeps the purchase in UK.
    Adam
  • CastroCastro Frets: 512
    Thanks Adam.
  • KebabkidKebabkid Frets: 3319
    Hamstead 20.
    A lower wattage Morgan - do you need the 35 for what you're doing?
    Divided by 13 JRT 9/15 - did you have one of these?
    Redplate
  • If I was you I would get a Brunetti singleman 50 and save £1500.
  • studio pro 50 sounds a lot better than the 35, I tried both in Coda
    Matchless HC30 would be my choice every time
  • Katana or helix
  • Kebabkid said:
    Hamstead 20.
    Redplate
    I must admit I tried a Hampstead recently and could t see what all the fuss is about. Maybe I needed to crank it a bit to let it show its colours ;)
  • peteripeteri Frets: 1283
    How about something from Carr? I have a Skylark - not enough wattage for you, but the bigger ones are stellar
    Coda can definitely help there
  • koss59koss59 Frets: 849
    I found the Two Rocks I had quite disappointing live, they were both 35's.
    Ive had a Carr Rambler for a while now which I consider to be the ultimate grab and go clean platform amp.
    Ideal in most venues but I've also used it on bigger gigs too.
    Facebook.com/nashvillesounduk/
  • timmysoft said:
    Katana or helix
    Katana and Helix...
    Not much of the gear, even less idea.
  • I'm going to say Bad Cat. The answer is always Bad Cat
  • Me too. Or 3rd Power.
    Thank you all for your suggestions.
    I now have a few hours surfing/research to do .
    One other suggestion is a Thornton amp. He does a single amp that is extremely versatile - 2 channel with blendable voicing. Very personable chap who builds them, and can come in combo or head + cab. Very little about them online unfortunately, but profoundly better value (and you communicate with the chap who designed and builds them) than the American boutique brands.
    Adam
    Thanks Adam that's a maker I've not heard of.
  • revsorgrevsorg Frets: 884
    A ground-up Cornell custom build
  • Are Zs out of vogue? I've always found them to be great live (the couple I've owned anyway)
  • Go and talk to @RiftAmps ;
    Pretty much any variation of amp and customisable to significant levels.
    Castro - DrBob of this forum has a Thornton so may chime in - and i am waiting to pick mine up (in fact i ended up not buying DrBobs Budda and ordered a Thornton after hearing his). If you dont mind waiting, and are ever up in Scotland you are welcome to try mine out.
    Cornell is a good shout to. Along with Rift, Flynn, Gartone, Gryphin, Rosewell and several other UK builders i have probably forgotten.
    Adam
