Hey guys,
So I picked up a Mark V:35 Head recently and I love it. Only thing is the footswtich is a four button affair for EQ and Solo 1 & 2 functions ontop of the channel select. It's a bit a large footprint to have on my board considering I only require use of the channel select switch.
I noticed the pedal is powered and interfaced with a MIDI cable so I was wondering if I could get a singular switch pedal to use as a channel select.
I'm not sure what midi channel values Mesa use or what pedal I could acquire (or build) so any help you guys have would be greatly appreciated.
Cheers,
Shaun
Picked it up second hand for 40 quid, easy to use and small enough to attach to the back of the head or stick it on the pedalboard.
http://eng.emcustom.eu/midi-interface.html
No custom cables needed
I have the V35 and the footswitch control is a bit frustrating as I wanted to control via another pedal as the Boogie one is a bit hefty
You could make your own footswitch using the custom connector.
1) +12V
2) Channel
3) Solo
4) EQ
5) EQ Led
SH) 0V (ground)
I did see that, but some people seemed to disagree with it.
