Looking for Hamer Centaura 2HB
Hi chaps,
l'm on the look out for a Hamer Centaura 2HB.
Most of the models you see come up are built with HSS configuration, the model I'm after has, a pair of humbuckers which are both slanted with the treble side of the pickups toward the neck. Different to a Diablo
The 2HB model was going to be the Hamer SS3 (third Steve Stevens Sig), but it never happened.
You see Steve Stevens Sig Washburns (USA and Korean built) with the same configuration occasionally from the early 90s if anyone is familiar with them.
Something like this would be perfect - but I'm not too precious about what finish it comes in or if its a maple fingerboard or not...
Looking forward to hearing from you
Cheers,
Ben.
* Hamer Watson, SS2, Vintage S, T62.
* Music Man Luke 1, Luke II
Please drop me a message.
I have the top one it has a bit of history and is well toured as it was owned by Laurence Archer who used it with UFO and Medicine Head
They are brilliant guitars mine is sadly not for sale but they do pop up from time to time especially on the states on ebay
goid luck mate
cheers
g
This is one is an HSS, is your and HH?
cheers
g
my one actually does not have the slanted pick ups you are after I will take some photos anyway
But check ebay USA as you are probably more likely to find one there
cheeers
g
Hamer Centaura Deluxe, Blueburst (never seen another to this spec and finish)
Hamer Centaura Custom. Solid Flamed Maple body, SD PAs - Custom order, one off...
I'm unlikely to need another HSS Centaura (apart from a beater ) hence the 2HB model search
... Nice aren't they
