Pair of JBL EON 305 speakers - NOW SOLD!
Selling a pair of JBL EON 305 speakers. Top quality passive cabs, ideal for general PA use and also as stage monitors.
These were bought a couple of months ago for a project which didn't happen. They are completely brand new / unused,
and are still in their original unopened boxes.
Originally retailing at £899, online discount price was £599 a pair. Mine are £350 a pair, saving £249 on discounted price!
Speakers are near Hull, East Yorkshire. Cash on collection definitely preferred, possible help with delivery / meet up
depending where and when etc. Message me for possibilities.
Full spec here -
* 250 watt Passive Speaker System, with a 500 watt program power and 1000 watt peak power rating
* Light Weight, at only 15 kg (33 lbs) it is truly portable
* Multiple handles for easy transport
* JBL 15 low-frequency driver with a 64mm (2 ½ in) diameter edge wound ribbon voice coil
* 1 throat diameter next generation JBL neodymium compression driver.
* 100° H x 60° V asymmetrical waveguide for uniform audience coverage
* SonicGuard™ HF protection
* NL4 and ¼ input connectors
* Loop thru signal flow for extended system application and easy “daisy-chain” connections
* Integrated M10 suspension points for easy rigging
* Multi angle enclosure for main or monitor applications
* Integrated 36 mm pole mount socket with stabilizing securing screw
* Highly designed composite enclosure for durability, lightweight, and acoustic performance
System Power Rating : 250 W continuous
500 W program, 1000 W peak
Frequency Range (-10 dB) : 38 Hz - 20 kHz
Dimensions (H x W x D) : 685 mm x 438 mm x 366 mm
(27 in x 17.3 in x 14.4 in)
Coverage Pattern : 100° H x 60° V nominal
Maximum SPL : 128 dB
Net Weight : 15 kg (33 lb)
Applications :
* Live sound reinforcement, speech and vocals, music playback in entertainment, A/V, and institutional venues – especially when ease of use and portability are important factors.
* Perfectly matched for powered-mixer systems.
