FS/ Morgan SW22R combo ****SOLD*****
Alex335Alex335 Frets: 122
edited October 2017 in Amps £
in fantastic condition with custom made heavy duty cover,
Fantastic amp based on a blackface deluxe reverb with a touch of Dumble. ( bright/dark & bass boost/Normal  switch )with a lovely lush reverb, great for loud hi headroom clean from sparkling BF type cleans to that smoky blues John Mayer type tone.
can also be set for breakup at low volumes with the clever level and volume wizardry
very versatile amp for the single channel clean type thing, can be set for high headroom even with hum buckers or a nice breakup at a reasonable volume
fantastic pedal platform amp
heres what morgan have to say
The SW22R offers the same tonality of the SW22 including its ultra-sensitive pick attack and singing sustain. The SW22R reverb is also run parallel to the original tone stack. This means when the reverb is not being used it is totally out of the circuit unlike most other guitar amp reverbs. Intentionally designed to be the loudest cleanest it could be with 2x6V6s it is still capable of producing a warm compressed natural overdrive. The SW22R utilizes a special level control. Its job is to control the amount of gain available in the power section of the amplifier. You will notice after about 3 o’clock on the level control you are adding overdrive to the power section. This allows you to use the level control at lower volumes without sacrificing your tone. The bass, mid and treble controls interact with each other to give you a wide range of tones. The Bass Emphasis switch changes the center point of the mid frequencies allowing you to get even more bass out of the amp. The bright switch is designed to bring in enough top end for even the darkest guitar but without adding any ice picky highs. This amp was designed to be that familiar black face styled tone from the mid 60’s but with added clarity and string to string definition that is unrivaled in any similar design. This is a LOUD 22 watt amp. You will be pleasantly surprised with its light weight and small footprint especially when it blows much larger and heavier amps out of the water. Handwired in the USA.
£1,475  no trades   croydon area, happy to deliver within a reasonable distance.
