https://www.thegearpage.net/board/index.php?posts/20189677/
https://reverb.com/item/501615-landgraff-dynamic-overdrive-2013
http://www.boutiquegeartalk.com/pedals-effects-multi-effects/1486.htm
Quite an insight into boutique pedal bullshit.
I will say one thing for that Landgraff - at least he's wired the 3PDT in the less bad of the two standard schemes, which only uses one pole for the bypass and grounds the circuit input with the other. There are still the usual lack of shakeproof washers on the jacks and various other problems though.
Do you think the coiled battery wire is part of the 'mojo'?
He's no vertex so I don't feel too strongly about it...
