Make absolutely certain you drill properly to the right diameter or there is a possibility of splitting the heel, since you're going directly into end grain.
The 'Martin' position on the treble side slope will work as well, but it's more awkward because it's more nearly at a right angle to the side of the guitar.
wouldn't put a wood screw in (quality) wood without per-drilling the hole with the appropriate size drill bit - read up on it.
I used a drill on my Martin with the right size bit, but I did consider a smaller bit whilst weighing it up and now after reading this I'm glad I went with the larger bit.
I'm currently using a planet waves strap lock so it's not particularly a must do alteration.
I mark the position first with a small cross-head screwdriver (really! It's an excellent marker into wood) and check that it's definitely right before drilling - this also stops the drill bit from slipping.
The right size hole is one just larger than the 'core' of the screw thread but smaller than the outside of the threads. You need to drill in to the exact depth that the screw protrudes through the button - I use a piece of masking tape on the bit to mark it.
