Cleaning Polish for Nitro Finished Guitars
CollingsCollings Frets: 411
Can anyone recommend a polish that is safe to use to polish/clean nitro finished guitars?
  • I bought a little bottle of Fender Custom Shop polish, figuring that all the Fender Custom Shop guitars are finished in nitro, so it would be a good bet. Does the job. Get a nice microfibre cloth while you're at it (although an old t-shirt would probably be just as good).
  • Gibson's "Pump Polish" - designed for nitro finishes.
    And, from memory, smells lemony! :)
  • Jack_Jack_ Frets: 3175
    +1 for Gibson Pump Polish.
  • JD50JD50 Frets: 660
    edited November 2017
    I just use an old t shirt to buff up my guitars.
    Polishing paint always sounds odd to me.
  • CollingsCollings Frets: 411
    I thought that might be a safe bet along with the Fender one.
  • OssyrocksOssyrocks Frets: 1673
    This stuff is the best:
    http://theguitarrepairworkshop.com/virtuoso-polish/
    I had a '67 335 with a really hazy finish and no matter what I used it either didn't touch or it actually got worse!
    Tried the Virtuoso stuff and it came up an absolute treat. I won't use anything else now. There's a cleaner and a polish. To be honest, I use the cleaner more than anything.
    Rob.
  • NiteflyNitefly Frets: 4924
    @Ossyrocks very interesting.  Do you know if it's suitable for satin finishes, e.g. Martin 15 series?
    I think you would need to be careful on a satin finish.
    I think there's a video demo out there, in which this stuff is used to bring a more gloss finish to a satin finished acoustic.
    Rob
    OK cheers.  I see they're in Salford, so I might go and have a look.
  • Virtuoso is excellent, been using it for years.
  • NeilNeil Frets: 3637
    People polish cars.  ;)
  • Are there any polishes that are particularly good for glossing up a satin nitro finish?
    Currently thinking about Virtuoso, given the above comments. Not expecting to be able to suddenly transform it into a high gloss, just a bit glossier.
    The Virtuoso cleaner will get you there, but it may take a bit of elbow grease too.
  • guitars4youguitars4you Frets: 14333
    I generally use Planet Wave Restore in store - you can use the Shine but that is more for just light cleaning of fresh fingermarks - Restore will help clean up old 'grime' - also use Maguires Car Polish especially on stubborn wear/grime
