Nervous Breakdown - anyone getting near his speed ?
  • Danny1969Danny1969 Frets: 10446
    Skrouff said:
    That picking technique doesn't work for me.  Try starting with an UP pick on the high E string(G note) then PULL off the G on the high E string then DOWN pick the B string(F note) and then use the middle finger to pluck the open high E string.  Repeat on the next two groups of strings starting with an UP pick on the B string and work your way up in groups of two strings with 1e&a.... rhythm.
    Thanks, that's similar to what I'm doing but I'm picking down first on the g note e string so will try up picking that in the pattern you suggest
  • StuckfastStuckfast Frets: 2424
    I've found a guitar pro tab for it online (link below).
    "Difficulty: intermediate"
    Understatement of the year!
