Strat wiring variations
So there are a number of different strat wiring options, I was wondering what people thought of them - from simple "apply tone to the bridge pickup" to various push/pull and blend options, and the special Fender double pot TBX tone control.
What are your experiences, do you find them worthwhile?
  • LebarqueLebarque Frets: 3920
    One tone control for the bridge and the other for the middle and neck. BUT... it always bugged me that the 'in between' positions sound a little less present and quieter than the others, so I use a superswitch to remove the tone pots from just these positions. Works a treat. I got the idea from Scott Henderson if I recall correctly.
  • You could also leave the middle pickup wide open, tone on neck and bridge. Jimmie Vaughan style. Some find it even enhances the quack positions.
    I find the blender circuit quite useful with a no load pot.
  • aord43aord43 Frets: 287
    Thanks - lots of reading about the superswitch now!
  • normula1normula1 Frets: 640
    On all mine I wire the lower tone control to tame the bridge and the upper tone control for the other four positions. on a couple I've also got an S1 switch that changes position 4 from neck / middle to neck / bridge and position 3 from middle to all three.
    And on Strat that's in the process of being revitalised I'll be having positions  1,2,4,& 5 as normal and position 3 being neck & bridge.
    I was thinking of doing what you have now, using a push/pull to bring in the Bridge, and changing the tone to work on the Bridge.
    I really love the sound of the neck and bridge and think that's well worth doing if you like it too.
    I don't know if I will like it until I have done it :)
    I decided to install it cause on another guitar I have with HH config and a coil split, I loved the centre position with the coil split and on the strat it's even nicer :)
  • bbill335bbill335 Frets: 1391
    edited November 2017
    I know most people use a blender pot for this; is that simply because there's a pot there already and it maintains the classic look? I think I'd rather have a no load master tone and a toggle switch to bring in the bridge on the 4/5 positions (or the neck on 1/2).
    What toggle switch could do the job? Spst?
    I used the blender pot and exactly for the reason you mentioned - that it's already there.
    It was actually a bit cumbersome having to turn a pot to 10 and a toggle switch would be a lot better. I looked into the S1 switch but thought it was a ripoff.
    As far as I can tell, an SPST would work as you'd just connect the neck (or bridge) directly to the output via the toggle then use it to break or make the connection. I hesitate to give advice though as I'm very much a novice when it comes to this.
  • ICBMICBM Frets: 72740
    I eventually came to the conclusion that a simple master volume and tone (250K Log pots, 0.047uF cap) setup with the five standard sounds and an overwound bridge pickup sounds the best to me - I'm not really a fan of the bridge/middle position usually, but a fatter bridge pickup helps stop it sounding so thin. Ideally with a custom pickguard with the volume control further away from the strings, but not as far down as where the first tone control is.
    I can't stand any of the Fender 'special tone circuit' nonsense, not one of them sounds as good as a simple pot and cap, and all of them have irritating side-effects, mostly clicks as the knob reaches the detent, or when switching pickups.
    I did once like the idea of a Strat/Tele hybrid with the neck+bridge in the 'bridge+middle' position, one tone control for the two 'Tele' sounds and one for the three 'Strat sounds, but it's just unnecessarily complicated and doesn't sound like a Tele anyway.
  • FunkfingersFunkfingers Frets: 14599
    I sympathise with this view.
    I have a 2012 Fender Tele-bration model guitar that, in my opinion, was ruined by the inclusion of a No-Load tone control. Too much harsh top end. No, not the Roy Buchanan squawk thang. Just a surfeit of ear fatiguing high frequencies.
    After converting to a high quality regular A250k pot, normality was restored. I am now tempted to upgrade the selector switch for a Jerry Donahue or Dan Armstrong "half-out-of-phase" circuit.
