TC Tube Pilot Overdrive with 12AX7
TC don't know what to be up to these days apparently
  • Is it me, or does that sound absolutely dreadful?
    It's not you
    It's put me right off tubes, or 'valves' as I like to call them.
  • TateFXTateFX Frets: 114
    The rehoused berhringer series continues.
    Formerly Stu_Tate
    Tate FX
    www.TateFX.co.uk
    Instagram
    It needs to be rehomed - not rehoused....
  • OssyrocksOssyrocks Frets: 1675
    That sounds terrible !
    If if you were going to make a promo, this isn’t how you do it.
    Astounded!
  • Wasn’t THAT bad. I’ll give it the time of day if the opportunity arises. But then I like things that sound rough rather than smooth.
  • AlvinAlvin Frets: 416
     TC into cloning now then or is it just a coincidence it looks like a BK Butler Tube Driver.
    They mentioned (vaguely) that it was based on something in the vid. The graphics are pretty obvious though!
  • It's only 49 dollars in the states
    Why, what is it?  Are they rehousing them plastic things?
  • thinking it was a good idea to remove the EQ and boasting about the fact that they left nothing much intact of the original circuit...and then thinking that’s a good thing, winds me up a bit. Cocky bastards.
    We’re talking about a classic piece of gear that doesn’t need to be altered to the point of sounding shit.
    The TC Smorgasbord series are all Behringer pedals in different enclosures with slightly improved components. Only the booster and reverb pedal are new I believe.
  • That's really one of the worst pedal launch videos I've ever seen, It sounds like one of those little battery amps companies knock out as novelty gifts...
  • stonevibestonevibe Frets: 7179
    Sounds like a Behringer piece of shit valve overdrive pedal.
    Lots of people loving it on the TC Facebook page. Whatever floats your boat I guess.
  • relic245relic245 Frets: 965
    Sounded shit to me too but the bit that I really don't get, why did that guy have a bird head on?
    Because he or she didn't want to be associated with that pedal.
    I believe it's a rehoused behringer vintage tube overdrive.
    Not sure that the Behringer Vintage Tube Overdrive pedal is a classic
    But, but, but he said they had reworked a classic pedal and refined it and improved it until the original circuit was unrecognizable... oh. He meant behringer..
