If your phono stage, your CD machine, your tuner, your cassette machine, your video audio output etc are all at line level, what exactly does a pre-amp do for you, if your power stage will accept a line level input? Could you get away with a signal switch box and a volume control? Is there really any need to buffer the signals with more active devices?
Hope that's not a silly question. I have various signal sources connected to a Conrad-Johnson preamp, and its output goes to a Leak Stereo-20 via a QED volume control box because the CJ preamp puts out too much for the Leak's input sensitivity. I also have in my music room a Studiomaster Series 5 desk whose monitor outputs go straight to a Quad power stage. Apart from that, all my previous hifi experience has been with integrated amplifiers so I've not had to think about it.
Traditionally, pre-amps provided buffering, switching, tone controls. The main "pre-amp" function was for the phono stage especially where low output "moving coil" cartridges were used.
Not a silly question at all. Passive preamps, as exocet just mentioned, are available in all the glossy hi-fi magazines.
They are sometimes incredibly expensive for just sockets, switches and volume pots though. They really tend to go to town on brass, gold and pretty timber![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
If nothing else, the preamp does present a high impedance to its source, maybe support internal phono stages, and allow routing between inputs & outputs.
Whether this is still the case, I don’t know. I suppose it helped sell pre-amps....
.....and the extra power supplies for preamps
http://petertyson.co.uk/index.php/naim-power-line.html?gcpc&gclid=EAIaIQobChMI582Aoqr21wIV6LztCh1BEgssEAQYASABEgLj6PD_BwE
