Peavey Classic 20 bargain
So my dad found a Peavey Classic 20 at his local auction and managed to score it for £80! When he got it back he found a Guyatone Digital Delay stuck to the speaker magnet as a bonus!
That's my Christmas present sorted!
1reaction image LOL 6reaction image Wow! 0reaction image Wisdom
  • stonevibestonevibe Frets: 7177
    I have one of these, great little amps and that was a bargain and a half!
  • Nice. When I used to gig (and smoke) there was a Foster's pub ashtray that lived on my speaker magnet so I didn't have to find one while setting up. :)
  • ICBMICBM Frets: 72707
    edited December 2017
    Try a 12AT7, 12AY7 or even a 12AU7 in V1 - it will open up the range of the gain pot, so it doesn't go from off to Metal Zone over the first quarter turn .
  • ICBM said:
    Try a 12AT7 or even a 12AU7 in V1 - it will open up the range of the gain pot, so it doesn't go from off to Metal Zone over the first quarter turn :).
    Good tip, cheers!
    I only want to use it as a practice amp at home, will this clean it up?
    Yes. Sorry, I meant to type 12AY7 as well in the post above - edited. The Y is probably the best choice - the T can sound a bit 'cold' in a gain position, and the U might overload the plate resistors - it worked OK when I tried it, but I'm not sure I would run it like that for a long time.
    Finally got round to getting a 12AY7 for the amp and it's totally transformed it.
    Much more usable range of gain now, thanks for the advice!
  • Great deal, you could probably flip it and get double your money back or more!
    Yeah I know!
    I'm enjoying it as a practice amp at home though, much more inspiring than the little solid state Vox I had before
    Glad to have helped :).
    The amp was designed in the late 80s-very early 90s, when "more is more" was the principle when applied to gain... I never found it had any usable range above about 4 with the 12AX7 in. The 12AY7 should make 12 roughly what 4 was before :).
    Yep - I mostly play clean with pedals for drive.
    I couldn't go above 1.5 on the volume before it started overdriving before. Now I get a nice usable range of clean
