But all very very tiny in the processor.
My feedback thread is here.
https://www.computerhope.com/history/processor.htm
However, you don't actually get any more work done per unit time, because the "Operating Systems" are 90% bloatware, and the application programs have just as many bugs in, and have their user interfaces gratuitously changed from one release to the next so you can never find the function you need - and if you do find it you realise they've subtly changed it in a way to make it less usable.
What you have to ask then, which is the more important - the software or hardware machinations...
You can also try shouting at them, but generally they aren't listening.
Well, that's how a computer works.
Magically making tiny psychic gnomes hide in computer boxes to make your work more difficult in surprising ways.
Processors are made of multiple transistors, which are used to construct logic gates (AND, OR, NOT etc.), which are in turn used to perform binary operations such as addition or subtraction.
The input data arrives at the processor through the data bus as a set of bits (how many depends on the bus width). The CPU then runs these bits through the logic gates on the next clock tick, and produces a different set of bits representing the result of the operation. The output bits are then sent through the data bus and stored in memory.
So how does the CPU determine which operations to perform on the data? Well that’s where software comes in. The code that software developers write gets compiled into machine code, which ends up on the instruction register of the CPU.
Of course this is a very simplistic view, but at the core (no pun intended), it is how computers work.
Brilliant but would your granny understand that lot?
With AI, computers are figuring out how we work. First it was LOLcats, then it was Facebook, then Cal of Duty, and why not Snapchat 'knockout games' and next it'll be real life Hunger Games. Wake up, sheeple! Skynet. Etc.
