SORTED - 2 amp heads into 1 cabinet - how?
CastroCastro Frets: 512
edited December 2017 in Amps
Opinions needed.
What’s the best way to run two amp heads into one 8 ohm cabinet, one head for cleans the other for dirt?
Thank you in advance.
  • martmart Frets: 5205
    Radial Headbone.
  • CastroCastro Frets: 512
    Thanks @mart
  • ICBMICBM Frets: 72666
    Is it a single-speaker cab? In which case you need something like the Radial.
    If it’s a multi-speaker cab it’s probably easier to mod it for two inputs, in which case you could also use different speakers for the two sounds as well, if you want. Although it can sometimes sound a little odd driving only one speaker in a cab. (Or two in a 4x12”.)
    It is a 1 x 12 Morgan cab.
  • ecc83ecc83 Frets: 1639
    Was! Going to say, "cheaper to buy another 1x12" but How The F do they justify 1/2 a bag for a one by 12? !!!
    Dave.
  • FezFez Frets: 536
    1/2 a bag is that £500? in other slang a "Monkey"  Must be a lot of Unicorn tears to make it sound four times better than a Harley Benton 1x12
    Don't touch that dial.
  • Modulus_AmpsModulus_Amps Frets: 2596
    Better materials and western labour rates... same speakers though..... Cabs do make a difference
    Well, Zilla can do a Creamback loaded 1x12 for £300, lot less  for cheaper drivers.
    A Fender 1x12 is £175 here Made in Mexico which I would think would be more expensive than China?
    I still reckon £500 is taking the piss.
    Dave.
