Found a NOS Mullard!
  • nick79 said:
    This seems as good a time to ask as any, what were/are 6bw7's used in?
    AFAIK, 6BW7 is another name for the EF80 which, in Britain, was used mainly for TV signal amplification in the late 50s.
  • RiftAmpsRiftAmps Frets: 3173
    “Receiving valve” suggests to me that wireless radio sets were what they mainly used for.
    Three different valve ‘categories’
    - CRTs or other ‘display’ valves (Nixie, Magic Eye etc)
    - Transmitting valves, used to process and send signals, usually huge buggers that need many kV to operate
    - Receiving valves, used to process and receive signals, used in TV, Radio, HiFi, Guitar amps. Essentially the ‘anything else not listed above’ category.
    The EF86 is just a high-gain audio pre-amplifier designed to be used in the earlier stages of a device (by ‘gain’ we mean voltage amplification, not overdrive). It was popular with designers because it could greatly amplify a signal using a very low HT. Check out the Mullard 3-3 HiFi to see one running in starvation.
    I regularly come across the 12.6v heater version, the UF86, in radio sets
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • ICBMICBM Frets: 72494
    EF86 is a low-power pentode. You find them in Vox AC30s and Radford power amps (amongst other things).
    Only very early AC30s with two channels. Almost all use ECC83s instead.
  • PhilKingPhilKing Frets: 1486
    I have a Vox AC4 that was modded to use a 6BR7 instead of an EF86, as the sound is very similar, but they don't have the noise issues.  However, they aren't pin compatable.
    If that’s an original AC4, there’s a very simple mod which will give more power and a richer sound, at the slight expense of a little more background hum - move the feed to the OT from the second filter cap to the first.
    I wish it was an original, but it is a reissue.  They sound pretty good but use a 12AX7, having the mod done gave it a much bigger voice.
  • 57Deluxe57Deluxe Frets: 7344
    edited December 2017
    @rico ;;;;  - you wanna putyour feet up and watch this then...Documentary on Valve production at Blackburn works
    <Vintage BOSS Upgrades>
  • DJH83004DJH83004 Frets: 196
    great link from 57deluxe, please watch it from start to finish to understand why Mullard, Brimar, Philips etc were the best in the world - for me the greatest thing is the machines that made the valves - top engineers who designed and produced them.
