Sometimes my active near-field monitors hum
The suddenly ramp up in volume as if someone turned up a volume control
They both do it at the same time, and continue unchanged if you press the mute button on each
After a while it goes away
I wonder if the mains supply is noisy, I can't see anything else in the room changing
  • thermionicthermionic Frets: 9674
    Teach them the words?
  • Winny_PoohWinny_Pooh Frets: 7831
    edited January 2018
    CRT monitor somewhere, lights on a dimmer switch? Fridge nearby?
  • spark240spark240 Frets: 2095
    Maybe......any definitive times of the day or night ?...you had any new wi fi gadgets recently?.....turn off everything possible in the house .
    mine comes from the kitchen dimmer switch...
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • ToneControlToneControl Frets: 12019
    it's been doing it a long time, none of those nearby
    I may have to go round switching things off I wonder if it's the CH pump
