What PA are you using?
  • JalapenoJalapeno Frets: 6399
    For smaller gigs, oldskool Phonic mixer-amp, 375w per channel, into passive Collins (cheap) 12" + Tweeter cabs.  Use the same speakers for foldback.
    For bigger gigs we use the amp as a power amp only and have a 24 channnel Behringer mixer, IEM  etc
    I wouldn't describe our solution as robust or high performance/fidelity, so no (more) lectures please.
    If we were starting again I'd opt for powered (brand) speakers and a small mixer, and grow from there.
    Feedback
  • robinbowesrobinbowes Frets: 3055
    I've made a decision and gone for an HK Audio L5 Power Pack. I got a really good price from Bax Shop and ordered it today.
    Looks like this:
    Hopefully should cover us for most gigs.
    R.
  • John_PJohn_P Frets: 2750
    Looks like this:
    R.
    That’s a nice rig - should be easy and quick to set up and spend good.   I’ve got two HK systems and really rate them.
    I already have a couple of the tops that I use with my Helix and I'm very impressed with them.
    Looking forward to cranking up the whole rig - 4.4KW, should be OK for the local pub :)
    R.
  • andyozandyoz Frets: 718
    edited January 2018
    I don't know much about HK but that Linear 5 rig looks good.
    The subs are interesting...using dual 12" drivers in band pass cabinet. It means the rig is not that wide so good for pubs.
    edited January 2018
    Interested to see how HK goes on the first gig..
    I use a similar mixer-amp for pub gigs, paired with a pair of Peavey Pro 15s. Not exactly top spec stuff, but I put it together for around £150 and it does the job pretty well. Plenty loud and reasonable sound from it for a rock band. If I was playing out more often, I'd probably look in to better gear, but this stuff will do in the meantime.
