Is it just a case of when to use the terms minor 7 and b7?
raising and lowering intervals is sharpening and flattening, or augmenting and diminishing
if you raise a 3rd for example, it's still a 3rd.. even if it's been double sharpened..
so for example.. if the note C was a major 3rd and was raised by a tone.. double sharpened, it would not become a D [even though it'll have exactly the same pitch as a D].. it would become C##
which is not nice at all I'll agree... but that's what it would become..
A suspension is an event that is a transition between two chords.
Typically when you change from one chord to another, all of the notes [that need to] change do so at the same time.
But this does not have to happen. You can change all of them but leave one where it was and then change it later.
Essentially, one note hangs over from the previous chord which creates a dissonance.
When this note changes to the note it should be in the target chord the dissonance resolves.
Possibly without knowing it, you will without doubt have heard this many many times before, especially in classical and church music [hymns: because their harmony typically follows 17th century rules].
A suspension has three phases:
1 - preparation: this is where the note to be suspended appears in the chord that is to be suspended
2 - suspension: this is where the note is suspended, so all the notes of the chord change to that of the next chord except for this one.. it 'hangs over " from the previous one.. hanging... suspending.. this creates a nice dissonance..
3 - resolution: this is where the suspended note changes to the note that belongs to the next chord and so resolves the suspicion and therefore the dissonance becomes a consonance... releasing the tension on the dissonance..
imagine a I - V progression in C
this is C - G
E---D
C---B
G---G
C---G
nice and easy so far..
so if we take the higher C from the C chord [preparation] and allow it to 'hang over' into the G chord [suspending it], it'' be a 4th with respect to the root of G. Therefore a suspended 4th.
The suspended 4th in the Gsus4 chord [the C] then resolves to the 3rd of the G chord [the B]
we get this
1---2---3--- [where 1 = C chord, 2 = Gsus4, 3 = G chord]
E---D-------
C--------B-- <-- C preps, then suspends, then resolves to B
G---G------
C---G------
As for C##
but I can totally see that.
Just for clarification, a SUS chord is intended to resolve from either a 2nd or a 4th (or 9th / 11th) (a chord tone in the prior chord) to the third of a subsequent chord. Are there any other instances of similar movements from & to other intervals being badged "SUS" ?
for clarification a few rules:
You only tend to suspend notes within the triad [root, 3rd or 5th being suspended as sus2, sus4 and sus6 respectively].
I've never come across 9th 11th etc as suspensions: which makes sense as they're outside of the triad
Most commonly [but not always] suspended notes resolve in the downwards direction [a sus4 becomes a 3rd for example].
The suspended note must resolve stepwise [sus4 to 3rd but never sus4 to root].
The suspension must remain in the same part [in old money, if the note in the alto part was suspended, the alto would resolve it; so it cannot switch to another part like a soprano or tenor... or change octave].
also... you can perform more than one suspension at a time..
imagine moving from chord X to chord Y by moving one note at a time [JS Bach loved doing this.. creating sequences of dissonances all stacking up.. when they all finally resolve it's like the music makes a great sigh of relief]..
you can also make chains of suspensions one after another [JS Bach loved doing this too]
for example: I - Vsus4 - V7 - Isus4 - I
in the case above, I - vsus4 - V is as I previously described
when V becomes V7, the 7th becomes the prep for Isus4
this is very common / very beautiful and often used at the end of pieces
1-----2---------3--- [where 1 = C chord, 2 = Gsus4, 3 = G chord]
I - V sus4 -- V -- V7 - I sus4 -- I
C--Gsus4----G---G7---Csus4--C <=chords
the notes [highest at the top / lower case = the note is already sounding from when it was first made to sound]:
E-----D--------d----d------C------c
C-----c--------B----b------G-----g <= 1st C preps, 2nd c suspends, then resolves to B
G----G--------g----F-------f-----E <= F preps, F suspends, then resolves to E
C----G--------g----g-------C----c
Nice movement in your example, just my sort of thing, and if it was good enough for JS Bach
I just wish I had paid SO much more attention in music classes back at school, and the teacher would have been so pleased to have an attentive pupil too. I was probably the most interested in class, but it was so un-rock & roll ! The benefit of hindsight (and a few years on the clock) I guess. Thanks for helping me to catch up on lost time chaps, keep the education flowing...
and I didn't qualify for grants, and student loans didn't really exist then, so it was all my own 'hard earned'..
btw - I actually use all this stuff in my song writing [of all kinds] and composition..
so all this knowhow is not limited to just reproducing 17th / 18th century music and / or passing exams..
there is real beauty in this stuff and can be just as relevant in a song today as it was in a piece 200 years ago..
so what's the difference between sounding modern or sounding Baroque? context and how you use it
hopefully, this explains a little why I make a distinction between D5 add11 and D sus4
they are formed and so behave quite differently
I know that you live music deeply @Clarky , so the history forms a continuum, which gives a valuable perspective to your contributions here on the forum.
I found the distinction between D5 add11 and D suss4 both interesting, educational and logical.
Yes, I have to agree about paying hard earned cash for your education, I did a Masters in Digital Imaging as a mature student. You are there because you are interested and choose to learn, and the pain in your pocket soon reminds you to stay focussed ! I do wish that I hadn't walked away from the music business so many years ago though, it was always my first love and passion in life. Disillusionment set in, so it became history (a good one, but history none the less). So now I am making up for lost time, theory was always my weak point, and the support of the forum is priceless in that regard
(and also the most elusive)
I think it is what i perceive as ambiguity between describing melodic intervals of flat 7th, minor 7th or 7th (as opposed to major 7th), and the fact that it is simply referred to as the 7th or dominant 7th in regard to harmonic intervals.
It could be as simple as just a case of when to use the terms minor 7 and b7 too...
Is there is an accepted hierarchy of interval names, and any rules by which to apply them ?
BTW what is the delta used for, I have often seen it used as ∆7 for major 7, but I think that may be a wrong assumption on my part ?
∆7 for major 7 <= this is correct.. Root, major 3rd, perfect 5th, major 7th
gonna make a bit of a guess here.... a reasonable one though..
I think the b7 thing is a bit of an Americanism..
they [generalising badly here] talk about everything with respect to the major scale
so intervals can be flattened / sharpened..
personally I'm not a fan of this..
the way I was taught was..
2nd, 3rd, 6th and 7th can be minor or major
these can then be further modified by sharpening and flattening..
a sharpened major 6th or flattened minor 7th for example
4ths and 5ths are either perfect or imperfect
if imperfect they can be either diminished or augmented
I prefer this because it does not pin you to a scale for reference..
it's simply a set of rules for naming intervals..
like all conventions.. they only work when we all use the same one..
the cross population of ideas from both sides of the Atlantic via mags, web etc can cause confusion to a topic that is already not exactly without ambiguities here and there..
and of course... everyone is more correct than everyone else.. flaming wars.. death threats over chord spellings etc... lol..
there are even differences in conventions between universities / academies within the UK..
ACM is very American Jazzer... University of London is more classical based as you'd expect..
thing is.. I think some modern stuff was in some areas a bit of a reinventing of the wheel because the guys doing it originally may not have had the formal music education to describe things and so found ways to do so..
being popular form and not Uni based, it reached a wider audience and so stuck...
hence.. suspension being allowed to occur in isolation rather than being part of an event..
possibly a misunderstanding due to hearing the chord named without the context being explained..
and so it sticks.. Root, 4th, 5th = sus4 but without the how / why the sus bit is what it is...
another is the determination to try to spell all chords by assuming the lowest note has to be the root..
I often hear folks call the notes E, G, C, E augmented [which is incorrect] or Em6
to me it's a C chord in first inversion... much simpler.. and enables the chord to sit sensibly within a key
I'd suggest (with no proof mind!) that the modal era of Jazz has created this problem you describe with sus chords, treating them as 'sounds' to be explored in an improv context rather than a harmonic technique/device.
If people are saying E G C E is *E+ when it's actually E G# B#, or Em6 (E G B C#) is that not a problem with someone's knowledge of chord construction rather than any particular root bias? Like yourself I'd see that initially as a 1st inversion C triad.
I think the theory stuff mostly works in most cases.. there are just a few you encounter on occasion where things can be a little ambiguous or open to interpretation..
I completely agree with your take on the Jazzers..
I think that another area that could help muddy the waters are the people themselves pioneering the genre..
some would have come from a more blues background meaning that they write and play intuitively.. they may well have an amazing ear for what they're doing but lacked the formal education to provide them with the technical language.. and in amongst these guys there would also have been the 'Debucy / Ravel types' making the crossover from the modern classical world into jazz..
so you'll end up with a pool of guys with a wide variety of levels of formal education, but all musically super switched-on none the less.. all rubbing shoulders and sharing ideas...
there are some things about the American style of theory that I quite like.. mainly it's compactness..
none of this crotchet / quaver stuff.. 1/4 note / 1/8 note etc is so much more intuitive and efficient..
also I agree that the nature of jazz, especially as it's harmonic style is so unstable and unconventional [at the time] that evolving / developing a more efficient means of describing things makes a pile of sense..
I guess it falls apart with pretty much anything other than 4/4, but the American terminology made the difference between understanding beats and rhythms and not. Otherwise I'd probably still be struggling now!
What's in a name eh?
I was taught to grab all the notes and to try to rearrange them so that they stack in 3rds..
when you've done that then you have the chord's name..
and if the lowest note is not the root, then work out the inversion
and if the notes cannot all stack in 3rds, find a combination that stacks them best / accounts for as many as possible, then deal with the odd / difficult ones individually and finally determine the inversion
a modern thing I love and use a lot are slash chords...
not only to show inversion, but it also makes easier reading for more difficult chords when charting them out..
E7 4th inversion = E/D - which is quicker and easier than figuring it out
these are especially good if you're in a band / ensemble cos you can just go for the top chord and let the bassist deal with the root.. in a session it's nice and quick and enables you to more quickly think on your feet. for example E11= D/E
in modern theory that'll get you by for sure..
the main thing is that you have some means to recognise the chord and reliably be able to find it..
all my stuff about suspension is of classical origin [more accurately, Baroque] and is only important if:
- you need to pass exams in music
- you need to authentically compose a piece in a style from roughly the early 1600's to the late 1800's
- you just like handling suspension events that way cos it sounds cool
for me it was / is a case of all of the above...
I had to pass exams..
My movie trailer work involves composition with orchestras in an authentic fashion. My boss for this work is Tolga Kashif - a professional conductor / composer... so he spots this sort of thing and likes things to be "as they should"..
and... even in my regular song writing, there are moments where I quite like doing this because of the effect it creates..
like I said though.. whatever works for you, so long as you end up with the right outcome is all that matters..
on my chord charts though, your X sus4 chord would most likely end up as an X5 add11..
this is because I've been reliably informed more than once over the years that I'm a complete dick when it comes to this... lmao
I also teach guitar privately so I think its just a case of explaining it to someone else in a simple way.
won't be the first time or the last... lmao
