It'll have SC Humbucker(s) but I still can't decide.
Esquire or Telecaster?
single pickup.
if you are not allowing colour variation why should you get a tonal one
Instagram
Thanks Wez.
What about the Esquire tonal controls?
3 way switch.....
1 - Blower - straight to the jack
2 - Through Volume and Tone controls
3 - Onboard Fuzz?
What to do with the 3rd position then?
Killswitch !!!
Maybe modify it so the pos 3 is spring loaded or try to find one that's like that?
A split HB in the bridge won't have the sound I want.
I have a half-sized 'mini guitar' with a single SD HotRails wired with a series/split/parallel switch and the parallel mode comes in very useful.
That sounds really cool.
I'm going to be speaking to the oily weasel very soon.
to give you an idea how small the circuit is the next pic is a 6x7 piece of vero
http://a67.tinypic.com/e8wobq.jpg
You could put the battery in the neck pup cavity and the fuzz circuit in the wiring channel.
you would need a dpdt mini toggle to turn the effect on and a small pot for the amount of fuzz... load of room for that in the main wiring cavity if you use mini pots throughout I reckon...
YouTube “bazz fuss”... its a nasty sounding circuit (in a good way)
https://youtu.be/7_shXac8Vm0
Thanks for posting it though.
http://tagboardeffects.blogspot.co.uk/2013/01/emerson-custom-guitars-em-drive.html?m=1
Cant wait to see it, especially if it does end up as Blackjack! That would be a huge honour!!
I'm on ebay right now trying to find a decent badge for the headstock.
I am really honoured!!!
A guitar with my name on is quite a big thing!
