FS/FT Blackstar Series One 45 with Full Flightcase £400
Sevenof9Sevenof9 Frets: 182
edited January 2018 in Amps £
Flagship Blackstar Combo
This is the 45 Watt Version with full flightcase
Hardly used at home/rehearsal and never gigged by me.
In great condition with the odd cosmetic mark which does not hinder use.
Heavy with flightcase so collection only from Nottingham although will travel a reasonable distance
to meet halfway........
Original RRP including Flightcase circa £1400
Cash Price now £400 or may trade for interesting guitar with cash either way
From Blackstar
By switching both preamplifier and power amplifier parameters the Series One 45W delivers both Class A style tones with a bell-like ring and classic push-pull crunch depending on the mode selected.
The patented ISF control removes the limitations of traditional designs allowing you to tune the tone to exactly the sound you are looking for.
DPR can reduce the power down to 4.5W (This is really effective and is a different way where the voltage going TO the valves is variable so it's not simply getting a lower volume.
The tones are really usable with the DPR whilst holding back or diming it.)
BLACKSTAR S1-45 2X12 VALVE COMBO SPEC
  • 45W Watt combo with built-in DPR power reduction
  • 1 x ECC82, 3 x ECC83, 2 x EL34 valves
  • Clean channel with Warm (Plexi) and Bright (Class A) type modes
  • Overdrive channel with Crunch and Super Crunch modes
  • ISF equipped tone control section
  • Presence control
  • Master Volume
  • Series effects loop
  • MIDI switching
  • Speaker emulated output
  • 2 x Celestion Vintage 30 speakers
