I'm having a bit of spend lately it seems. I've been looking at the Pedaltrain 1 or 2. Unfortunately I've missed out on a Pedaltrain 2 with ATA case on here recently. However, the Pedaltrain 2 version is a little too large for what I need really albeit only slightly. So I'm going to go for the Pedaltrain 1 which has a different hard case. This is my dilemma, has anyone had any issue with the PT 1 hard cases? They just look a little flimsy compared to the Pedaltrain 2's hard case. Any experience/advice about these cases before I buy?
"Nobody is really researching robot jokes"
I know!
My new one will actually be slightly smaller than my old one, but because you can put the power supply and cables underneath, I should be able to use the space more efficiently. By the way if anyone wants a Diago Showman PM me.
I'm getting the the Emma Electronics one:
http://www.emmaelectronic.com/products/amarhyll/index.html
It's similar to a pedaltrain (probably copied it) but I prefer the dimensions. The PT3 is 41cm deep which is more than I want. To make use of that space you'd wind up putting pedals 3 deep on the board. The biggest Emma one is wider than a PT3 (76cm vs 61cm), but 31cm deep instead of 41cm.
It's also a bit cheaper than the Pedaltrain. They don't have the large one in stock at the moment though. I think I got the last one with a discount because there was a scratch on the hard case.
I totally filled my PT1 and I hardly ever even use pedals. The case isn't as bad as it looks although my son figured out how to open it pretty quickly so the latches aren't amazing.
https://www.thefretboard.co.uk/discussion/57776/handsomerik/p1
