SOLD: Hughes and Kettner Tubemeister 18 Twelve w/ upgraded speaker & valves.
Arktik83Arktik83 Frets: 431
edited February 2018 in Amps £
This is for my Hughes and Kettner Tubemeister 18 Twelve which is an 18 watt valve amp with a switchable power soak down to five watts, one watt or silent recording mode using the red box inside the amps cabinet.  I bought this from @timmysoft just before Christmas and he was an absolute gent to deal with.
Here's what Hughes and Kettner say about the Tubemeister 18 Twelve:
"Able to deliver three different sounds at the tap of a toe, the soulful TubeMeister 18 is the must-have guitar amp for gigging guitar players. Oversized transformers deliver tons of headroom with phenomenal dynamic range that sweeps from sparkling clean to snarling mean. The Lead channel offers harmonically rich tube distortion and gain reserves to go from grinding overdrive to soaring lead sounds. And the integrated Boost re-voices the Lead channel to conjure modern high-gain sounds that pair plenty of punch with endless sustain."
The speaker has been upgraded to a 12" Celestion V Type Speaker and the Valves were replaced to a much better quality set. The clean channel has loads of headroom and the lead channel has classic rock tones on tap and when you need to give it a little extra just hit the boost and you're good to go!
Comes with a two button footswitch which you can use to change the channel or engage the boost which offers great versatility and a H&K branded cover.
Has a few scuffs on the bottom of the amp but nothing that has ripped the tolex and the grille is intact/knobs are working perfectly.
Located in Blyth, Northumberland but can post via UPS courier.  Collection is also welcome.
Looking for what I paid which is £275 if you want to collect/£295 delivered.
Pics:
https://i.imgur.com/Y6t5PKM.jpg
https://i.imgur.com/Gn7N6lC.jpg
https://i.imgur.com/zZzmBOi.jpg
https://i.imgur.com/326TDSZ.jpg
https://i.imgur.com/s8VGx3r.jpg
https://i.imgur.com/kXb6Zj8.jpg
  • Arktik83Arktik83 Frets: 431
    Bumperoo.
    Bump
    Slam dunk da bump.
    Bump
  • VoxmanVoxman Frets: 4727
    Strange control layout to have the reverb on the rear panel and odd the head version doesn't have reverb. But nice sounding amps as far as a recall from trying one several years ago.
    Yep!  Not sure why the reverb is on the back next to the power soak.  It is a really nice sounding amp, nicely balanced and the crunch channel has your classic rock tones all day long.  I keep flip flopping and think about keeping it haha!
    Arktik83 said:9
    Shame you're not local to me so I could try out (I'm a long way away from you in North London)
