Marshall 6101LM 30th Anniversary 100W Combo
Marshall 6101LM 30th Anniversary 100W Combo with footswitch.
Owned from new. Never been gigged and is in mint condition.
Selling as don't get the chance to play loud anymore. Now using a Yamaha THR10.
£490
£450
Now a real bargain! £400
Andover, Hampshire
Specs:
Three channels, each with selection switches:
Channel 1 (mid shift and bright)
Channel 2 (contrasting crunch modes)
Channel 3 (gain boost and mid band contour selection)
Channel switching by footswitch, midi control, or from front panel switches with LED indicator)
Sensitivity switches, one each for low or high compensation, to match guitar pickup.
Power control allows high (4 valve, 100 watts) or low (2 valve, 50 watts) mode output.
Pentode or triode mode operation in either mode gives effective power range from 100 down to 25 watts.
Power amp damping control for tighter sound and fuller distortion: high, low, or auto.
Auto mode damping pre-selects the right damping to the correct channel.
Comprehensive effects loop provides level control, series or parallel selection.
Separate send level trim: one each for clean and overdrive channels (-10 to +4 each).
Balanced output with level control features authentic compensation for a real direct to board guitar sound.
https://www.dropbox.com/s/gakox009uowvy3e/$_86 (1).JPG
