Just tried a muff into the front, no audible difference with the zoom bypassed as opposed to the muff straight in to the amp
You can get the muff models included to sound pretty close.
The centa gold (klon) model is really impressive.
The amp modelling is absolutely fine if you use an ir instead of the built in speaker sims. Or with the sims off into an effects return.
I always use through an amp miked up
Most of the reverbs sound totally convincing. The delays are excellent.
The modulations are great, although the vibe is a bit weak imo.
The UI is ok. For live use you can use a line selector model in the zoom which turns all effects off after a certain point. So you can dial in a rhythm sound and then just hit the zoom for boost delay etc.
You can also scroll through a set number of patches.
Admittedly this is a weak point.
But you can use midi with a midi host (hobbytronics midi host is what I use, its £40) where you can change patches.
Power wise, it claims it needs 500ma but runs fine from a gigrig isolator which I think pumps out about 150ma (correct me if I'm wrong). It can run on USB but is noisy as hell if connected to my pc. Seems to like being isolated, although it will run daisy chained.
Reliability wise, it seems like its built like a tank, the body's all metal, the screen's protected by hard plastic.
All in all, I suppose it depends what your expectations are. If you're a professional rocking a dual amp setup or wet dry wet rig, I'm sure the strymons/Eventides are going to sound amazing. If you're at home I think it gets you 75% of the way there for absolute pennies and I'm not sure I would ever tell the difference.
It lets you try different combinations of effects without laying out £1000s
I own the 70CDR and 100BT (also had the MS50G at one point, so yeah, I like 'em!). The 70CDR is much less fussy with power than the 100BT but all of them need to be isolated to avoid noise. The 70CDR would run from an output off a Gigrig isolator but the 100BT won't - that one needs the GigRig Timelord adapter which delivers more current. Or of course, a dedicated power supply (or even batteries)
As for the interface, it really depends how you want to use it. I always used it as a one effect at a time pedal (plus reverb) so, I had one patch which had a reverb at the end (always on) and then in the same patch, I had a delay, a chorus and a phaser. At the start of each song, I just made sure the effect I wanted was selected and then turned it on or off on the pedal. Worked fine for me. Of course, you can set up multiple effects to turn on or off by using the line selector function or alternatively, put it in a true bypass looper and activate it from that.
The great thing about them is you can stack multiple versions of the same effect. So you could run a number of delays at the same time for example. I've just picked up an Empress EchoSystem which has the ability to run two delays into each other but the price difference and footprint size is massive compared to the Zooms.
Another example of the ability of the Zoom is EQ. Many praise the Source Audio Programmable EQ as you can programme 4 presets. The Zoom can run up to 6 EQ pedals per patch (Graphic OR Parametric) and store 50 patches, giving you 300 possible EQ presets!
Honestly , for the money you can pick them up for, you'd be mad NOT to get one. One of the best value pedals going in my book.
https://www.zoom-na.com/products/guitar-bass-effects/multistomp/zoom-ms-70cdr-multistomp-chorus-delay-reverb-pedal
Sweet, thanks @Beexter
The free firmware update offers up some good things from the MS-50 like Auto/Touch Wahs but as Chorus, Delay & Reverb go, it punches above its weight and being a bit of a Swiss Army Knife pedal, it's handy when you need an occasional effect but don't fancy forking out on a pedal version of it.
As Gassage mentioned recently, I believe Steve Mac, the 'Gilmour' in the Australian Pink Floyd, is using one or two of these for his sounds. I think that's got to count for something!
User interface is fiddly, but if you setup and save your favorite 3 or 4 presets at your leisure at home, you can cycle between them with the footswitch live, which works well.
The day I try and emulate Pink Floyd is the day that I sell my pedals and smash my guitars. Our parents fought in the punk wars so we didn't need to listen to that twaddle
Seriously though folks thanks for the info. I'll probably pick one up: they're just not very...exciting I guess. Hmm.
