GONE: Ampmaker P1800 18w Plexi type amp £325 collected
photekphotek Frets: 1468
edited March 2018 in Amps £
I have ended up with 2 of these but I really fancy the MJW on here so the posher of my 2 can go. Spec is in the link below, it has VVR so you can crank it at home levels.
Along with the built in VVR power control you can select 5w which uses 1 EL84, 18w with both or 18w+ which gives a rounder, less edgy tone. Has a switchable bass control which when removed from the circuit is purer sounding and grainier. The hot input gets you into Jubilee, 800 territory!
New JJ EL84s. I will add pics when I get home but it is in a brand new head shell made by Chris Uff in the usual black with gold piping stylee. I ordered the smaller of his cabs and specced the cooling vent in the top.
The amp is really quiet even when running at very high volumes. I can't seem to format adverts on my PC so please accept this as a placeholder until I get on the Mac later.
Looking for £350 Delivered to the U.K. or £325 collected Cambs area.
https://i.imgur.com/eTGww98.jpg
https://i.imgur.com/Bc2kFq9.jpg
https://i.imgur.com/DTKFeqY.jpg
https://i.imgur.com/xFTldnG.jpg
http://www.ampmaker.com/store/P1800-plexi-amp.html
