https://twitter.com/spark240
Reddit r/newmusicreview
Have you got it set to private or something?
Bass EQ'd with Sonar EQ, added bass amp sim Ingnite Amps SHB1 with Ampeg IRs, Slate EQ and compressor on the bass bus, a sansamp plugin clone and a send to the reverb room bus.
Main guitar is running through an instance of S-gear with a v30 IR, the reverb and delay running, EQ'd with Sonar EQ and Sonar 1176 comp, but of delay and bussed to a main guitar bus, wah has a channel strip on it with a doubler, EQ and delay engaged, duck guitars just have a high pass and the solo guitars had a reverse reverb, EQ and delay. All guitars out to the main guitar bus with a send to the reverb bus.
Vocal had Sonar EQ (HP, cut at 100hz and 3.5khz, boosts at 2khz and 12khz), Cakewalk version of an LA-2A, delay and small amount of doubler. Tracks were copied for the harmonies and I used Little Alterboy to pitch the harmonies. The chorus was a mix of a 4th and a 3rd. Microshift used on one of the parts. Had to freehand pitchshift a couple of parts in melodyne, send to the reverb bus.
Master bus had Slate VTM and VMR with the New York saturation and the distressor comp and then cleaned up with Ozone 8 according to what I heard on my headphones with the multiband comp, dynamic EQ and vintage limiter.
Think that is everything!
It's really useful to hear your processes. And loving the backing vocals. You can't really go wrong with some gratuitous backing vocs if they're not too high in the mix
