if you want a useable tube Reverb that actually works and sounds good, Steve Crow at Audio Kitchen makes a stunning standalone unit - check the vids on YouTube. Intended principally for use in studios, though it can work as a normal preamp Reverb too.
Moe_Zambeek said: I had one of the Matamp Series 2000 reissue Reverb units from new and it was completely useless, unusable. In fact I’d go so far as to say it was junk, which is not the norm for Matamp. Nor was it a faithful reissue. In any case, I wouldn’t bother with those.
if you want a useable tube Reverb that actually works and sounds good, Steve Crow at Audio Kitchen makes a stunning standalone unit - check the vids on YouTube. Intended principally for use in studios, though it can work as a normal preamp Reverb too. Thanks @Moe_Zambeek that's a shame about the Matamp, I kind of had high hopes for that unit.
I checked out the Audio Kitchen unit, there is only one YouTube clip that I can find which is quite short and the guitarist doesn't really do it justice. What I could hear of it was nice but according to the clip there was only five ever made!
Is it worth buying into more pedals or am I pretty well covered with what I have? Reverb pedals are the only GAS I have these days so would be a shame to stop the merry go round lol.
I echo the entiments above, matamp reissue was awful. Very hissy, noisy and weak. Fender reverb unit is a classic for a reason and I still own one, running into an Orange OTR120 head.
I also reccomend the Boss FRV1 pedal if you are after that specific fender reverb unit tone. Nothing comes closer imho. Fender tube unit sounds bigger and richer but at gigging volumes in a band you would be hard pressed to tell the difference between that and the Boss.
I have the Boss FRV-1 so that's good, I still wouldn't mind trying out the Fender unit but space on top of my amp is a little crowded what with the attenuator seated there.
Again, thank you to all for your wisdom and advice.
Bandcamp
http://www.thefretboard.co.uk/discussion/60396/
The trouble is they're expensive for what they are, I'm happier with our new unit but trying to get the cost sensible is proving difficult. In terms of construction time and components it's not far off an amp build!
The speaker cabs for those reissue sets were also coming with custom Alnicos, but when delivered had the usual Hot100s with some stick on labels. Oh, and there was to be a certificate in a leather folder too, and that was never to be seen either
The amp though - that was a corker. A beautiful sounding amp that was really nicely made too.
Edit to add: the above sounds like a rant about Matamp but they’ve moved on a lot since then and have much better QC and are way more transparent with what you are getting. The Series 2000 situation at the time really rankled with me but to some extent it was my own fault for not being more realistic.
I have played through a vintage Fender reverb unit too.
I don't think anything really compares to a real unit...you can compare pedals, but there are certain nuances to the big unit that a pedal can't recreate...but just as someone said earlier, the louder you play and with a band the less you can tell the difference. So it depends on usage...
so the real answer is...own both!
