Anyone got any good recommendations on volume lift pedals.
I’m talking in terms of something that’s almost fully transparent. Something that just takes your signal as it is, and just makes it louder.
Like a single stomp, with pre-set level.
Ive tried the likes of the MXR micro amp, TC spark etc.. and volume (expression type) pedals placed after dirt.
Just wondering if there are any other decent methods kicking about, with minimal added gain etc
Thanks for your help.
''i've not seen a reaction like that in here since George Best got kicked out for glassing a bouncer''
Award-Session used to make one, I'm not sure if they still do, but it's a very easy thing to have made if you can't find one.
If your amp doesn't have an effects loop, ICBM's idea sounds simple and effective, although if you're getting your overdrive from the amp, feeding it a reduced level of signal from the guitar may well give you a cleaner sound as well as a quieter one.
It’s cheap, it’s simple, and it works...
After all that, i ended up just pulling the trigger on a Keeley Katana.
Wanted to try one for ages.. got the older version with the voltage doubler.
They had me at:
''Want a mirror image of your tone, only louder? This is it. ''
See how that goes.
Thanks again!
