Speaker cables?
shaunmshaunm Frets: 1633
which ones do you use to connect your amp and cab?
  • ecc83ecc83 Frets: 1639
    Well, fine if you think you need them but...Probable worst case scenario? 200W into 4 Ohms, 7 amps rms, in practice a lot less because the amp will not be at full chat 100% of the time.
    More realistically 100W 4 Ohms, 5A rms. Much less for higher speaker impedances and lower amp power.
    Orange garden mech' cable is rated at 6A iirc and is more than adequate for anything you can lift.
    Can't be arsed to look but I am pretty sure that 7A is above jack rating? Do yours get hot?
    Dave.
  • ICBMICBM Frets: 72574
    1/4" jacks are rated for 6A.
    Standard 6A 2-core power cable is ideal - at guitar amp power levels you won't need anything more or be able to tell any difference. Anything much bigger gets hard to get into the plugs anyway.
    Use Neutrik NP2C or X plugs only if you can - they're better for speaker connections because they have no internal rivetted connections like other designs do, and a better cable grip.
  • octatonicoctatonic Frets: 33836
    I use old electrical cable because it is cheap and works fine.
    octatonic said:
    I use old electrical cable because it is free and works perfectly.
    FTFY :)
  • sgosdensgosden Frets: 1994
    I get Russ to make them for me..
    http://www.russandrews.com/kimber-12tc-speaker-cable/
    only £1000 per meter
    ICBM said:
    FTFY :)
    Are you the bugger who stole my old electrical cable?
    Not unless you left it attached to a vacuum cleaner in a skip in Edinburgh about ten years ago :).
  • kreggskreggs Frets: 64
    I dig a bit of lawnmower  cable for that tasty orange vibe! :)
  • Mogami gold ones and also Planet Waves ones as well.
