I use parts of the C shape for other songs, mainly the A and D strings and also for 7th chords.
Same with G shapes, but with the lower 2 strings only.
Use it all the time*. Tend to make it across 6 strings but only play 3 or 4 of them.
G shape, tend to make bits of it; top bit or bottom bit.
* The absolute classic being a move between a minor and its relative major (either way) i and I can't be arsed to move my hand across the neck.
https://youtu.be/IGrZrVcorBo
and 0:27 and 0:29 here:
https://youtu.be/0edZA765Tvs
An example below, there may be better ones.
Enabled him to pick notes in and around the chord as he so often liked doing
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
So, I might play:
F: 8x756x
F6: 8x776
Or:
12 x 9 12 x x
For Em.
The only time I'd play C or G shapes as a barre would be if I was doing some fake-capo-ing, or some Hendrix things. Neither of which I'd make any claim to be expert in.
Roly Poly - Bob wills
Dinah - Django (of,course, he used lots of,approaches)
lipstick on my collar - connie Frances
might be an element of the "used a lot..." part of,OP
I’m with Matt McG I don’t really play full barre chords, only 3 or 4 note versions.
I got better at bar chords because I'm lazy and couldn't be arsed to put a capo on for songs like Hotel California .... so I just used to bar all the chords and it sounded 80% the same which is good enough
I also use a moveable D shape a lot - miss the top string and you have a power chord that cuts through and takes up less frequency space than an A or E shape which can be handy if you have two guitars or keyboards.
1. That is the sound you are after.
2. You don't really know your chords.
Ged
