Ideal weight for a Strat?
13»
    wibble said:
    Whitecat said:
    thegummy said:
    Whitecat said:
    thegummy said:
    I tried but it's just impossible to balance the guitar on my kitchen scales without the scales tilting over to one side.
    What is it you guys are using?
    A digital kitchen scale. Works fine on a stable surface.
    For me, around 8 lbs or less is great. I don’t mind the under-7 lbs examples at all - they seem to be quite rare though and often very materials-dependent.
    Must be either the type or specific model of scale I have in the kitchen, it's just impossible to balance the guitar on it without the scale tilting over.
    Basically it’s this exact one except in silver - http://www.salterhousewares.co.uk/salter-disc-electronic-digital-kitchen-scales-white.html
    I can almost always place the guitar so the body curve is showing the weight readout.
    I have similar set of scales.
    I put a small plastic bowl/tupperware container on it first and then zero the scale, then put the guitar on it. Makes it easier to see the display.
    I tried with a small bowl but no joy, might try Tupperware since you have success
  • BucketBucket Frets: 7751
    octatonic said:
    Kitchen scales here too.
    Do you use the same scales to weigh whale testicles as you do your guitars and your Jennifer Anistons? Quite unhygienic.
  • octatonicoctatonic Frets: 33838
    The Jennifers do not mind.
    Dirty bitches.
  • Philly_QPhilly_Q Frets: 23083
    Try gluing the bowl in place.
    Hide glue preferably, of course.
  • TrudeTrude Frets: 915
    I stand on my bathroom scales and then pick up the guitar. Usually naked.
    Some of the gear, some idea
    Trading feedback here
  • horseheadhorsehead Frets: 220
    Pics or it didn't happen
    Loved my strat for years and seems the perfect weight releaved one for me (it had the finish burned off) at 7lbs 2
  • HootsmonHootsmon Frets: 15987
    do you think 6.3 lbs is too light for a tele guys?
    tae be or not tae be
    Not for a thinline.
    edited March 2018
     a regular 52 CS
  • WhitecatWhitecat Frets: 5452
    I’d do it. Some woods are going to be that light naturally anyway - but an alder or ash example at that weight would be pretty rare.
    heh heh...I asked the guys on the tele forum the same question and they were none too pleased and said....."too light for what?"
    and I said, too light for a tele
