Drums - kick, snare, overhead - easily mixed down to 1 with a cheap mixer
Guitar x 2 (mic or emulated)
Bass x 1 (usually DI)
Vocals x 3 (yeah, that'll have to come from the desk)
= 7 inputs
Get a Tascam US16x08 (£220), a cheap Behringer mixer (£40?), and a dual-band router (£30), job done for less than £300. That's a shitload cheaper than individual digital IEM gear times 5.
I really don't think the question is whether it's cheaper or do-able - that's a lock. It's really a question of whether it actually works reliably at usable latency levels, IMO.
But when it's released the pricing will be on a per-person basis, currently expected to be about $100/individual.
To answer your questions
1) There's the main Soundcaster software than runs on a mac. This needs the audio for each channel, but that's fairly straight forward from a digital mixer, otherwise you'd need to be using an audio interface of some description
2) It is iphone at the moment, but they're hoping to get the windows version of the software and an android version of the app released later this year.
I don't have the facilities to measure latency, but as soon as I've tried it I can let you know if the latency is acceptable.
...that kills it dead for me. With all the other gear involved, it does put it pretty close to the cost of traditional IEM systems.
A gear4music wireless system is about £70 per individual mix (would work out cheaper if people are willing to share a mix)
An LD system is about £175
A Shure system is closer to £500 per individual mix
So this audio fusion system is priced competitively at the bottom of the market. It could be a bargain if it provides a similar result to the mid to higher end wireless IEM system - but that's a massive IF at this moment.
1) 40hz-12khz, with minimum 40db of dynamic range (that is a reasonably large number to achieve - but a minimum standard) - most people will feel the mix is squashed with any less
2) we try and keep round trip below 5ms on IEM mixes.. most pro digital consoles are in the 2-4ms bracket (some need to be put into non-compensation modes for this) - and then we use analog wireless IEM to add no further latency. (if we are using digital wireless mics, we're talking 1ms or so for this)..
Most pro musos will feel more than 5ms, even if they can't hear or explain it. Towards 8-9ms it is pretty obvious. I can tell 5 and up every time,
Considering the hurdles big manufacturers in this industry are having making digital RF IEM systems that do this reliably, in a hardware box at £1000/channel price point... I seriously doubt this product can achieve the above..!!
My biggest issue regardless of sound quality and dynamic range is reliability.. Even if you use 5GHz, use a hidden SSID, etc etc... You are inviting hundreds of potentially hostile transceivers into your RF environment (everybody in the audience will have at least one WiFi device!).. A short dropout or significant packet loss when you're scrolling Facebook isn't really an issue.. But losing even .5 second of audio in an IEM is massively disorienting!
Then again, I'm guessing the rules are slightly different for vocalists.
Yes, there is a further issue at play with vocalists - occlusion - where you hear some of your vocal back physically because you have something stuffed in your ear.. If the latency is too high, you get a comb filter effect between the occluded sound and the IEM sound - which can ruin the sound of the vocal and make the singer very unhappy!
(same applies with effects though.. Rev (and sometimes even delay) in a stereo mix are a must for vocalists!)
