It's the "vintage natural" finish, aka blonde. I was surprised, and a little disappointed, that it was satin rather than gloss, but I've learned to live with it.
As already mentioned, it has a pretty big neck - almost as big as the 1940's L-50 that I had for a while - but it's very manageable.
It arrived with round-wound strings, which I've replaced with flat-wounds, 11's I think. I've also installed the included scratch-plate - It just looks wrong without it, to my eye.
I'm very impressed with the acoustic sound, especially with the flat-wound strings - I've been using it mostly for chordy stuff, which really gets it moving.
I've only plugged it in once, just to make sure it worked, so I can't really comment on the amplified sound. That said, it's a Shadow Nanoflex under-saddle unit, so I wouldn't expect too much in the way of jazzy woodiness...
All in all, I'm very pleased with it, just annoyed about the case, which I see is now available at an extra £129...
I thought the Deluxe sounded good on its own, but that the Olympic would be better when placed among other instruments. It wouldn't crowd other instruments' frequency ranges.
BTW I posted a pic of my 72 SG in the other thread, with he plugged mini-switch holes - intriguing!
Lurved the tone, size is just right.
EDIT I don't think you can say "they don't make 'em like that anymore" ... 'cos they do!
Already booked in with my tech for a setup job (new strings, adjust truss rod & bridge, set intonation etc). It's pretty good now tbh, but there's a strip of white stuff under the bridge supposed to prevent scratching if bridge moves in transit which if I remove it the bridge WILL move and I want different strings. But I'm very happy
I was quite tempted by the sunburst myself, but finally plumped for the blonde. Lovely ebony board, too.
I hope you have many happy hours with it
So I'll try to remember to report back after setup & new strings and after a go with my favourite brass plectrum. I expect to be reporting more volume than other equivalently sized acoustics.
I've still not got a bass but gimme time
@darthed1981 Yamaha RBX375 !
