Telecaster Bridge For Use With Bigsby Recommendations
Duppy03Duppy03 Frets: 104
edited April 2018 in Making & Modding
I'm after a vintage style Telecaster half bridge with brass saddles for my Telemaster build. It has a Bigsby installed so needs to be one that has the cut out areas at the back to accommodate the strings coming through from the back. Basically one of these:
https://www.guitarexperience.co.uk/hardware-components/callaham-hardware/callaham-vintage-hardtail-bridge-with-enhanced-brass-saddles-specialized-for-bigsby-flat-mount-styled-vibratos.html
I was on a thread just a couple of days back w here somebody (a fellow Devonian as it happens) had got hold of one from a FretBoard member but now can't find it to get in touch. Less than half the price of the Callaham one too I I remember right?
Any help would be much appreciated
  • MartinBMartinB Frets: 215
    I suspect you want something classier than this, but when I did the same I just bought a cheap Wilkinson half bridge and went at it with a hacksaw and files!
  • ICBMICBM Frets: 72673
    I would look for one with steel saddles if you can. Brass is too soft with a Bigsby - the strings sliding back and forward will cut into it and bind. You might be able to fix it with heavy lubrication but it will always be a bit of an issue.
    (And steel saddles sound better anyway ;).)
  • Duppy03Duppy03 Frets: 104
    Yeah i’ve Already gone that route and looking for something a little tidier
    Top tip @ICBM ;
  • GagarynGagaryn Frets: 1553
    I can confirm that John, as always, is absolutely correct. :-) I went through 5 or 6 different sets of brass saddles on my bigsby tele before giving in and switching to steel. Brass just cannot cope and gets notched in no time leading to binding and sitar noises.
  • JohnPerryJohnPerry Frets: 1622
    this is the Gotoh Bigsby bridge which Gavin (Axecaster) does:
    http://www.axecaster.co.uk/index.php?main_page=product_info&cPath=12_37&products_id=507
    Messaged Gavin and he’s hoping to get some more stock in soon including half size versions
