SOLD 2014 USA Fender Stratocaster Standard, HSS,
guitarhippyguitarhippy Frets: 45
edited April 2018 in Guitars £
Selling a 2014 USA Fender Stratocaster Standard, HSS, black, rosewood board, it hasn't seen a lot of use but has had a body repair because of some battering about on stage and looks well relic'd, the neck is in fantastic hardly used condition, the trem arm hole hasn't even had the sticker removed and has a non original hard case..looking for £450 Delivered
https://i.imgur.com/XiHuwed.jpg
https://i.imgur.com/V4QXr5s.jpg
https://i.imgur.com/wQKvod4.jpg
https://i.imgur.com/mgyAsls.jpg
https://i.imgur.com/Jqp4eib.jpg
https://i.imgur.com/7fiwJbo.jpg
  • TravisthedogTravisthedog Frets: 1849
    So has that bottom bit actually snapped off?
  • No, as far as I can see with the paint work it never came completely off.
  • So what's the damage like on the bottom bit, is it loose/wobbling or just a big gash?
  • There are no loose or wobbling bits at all, everything is all fixed quite solid.
  • Forgot to say it also plays great with really low action, ALSO Delivery will be next working day...
  • simey83simey83 Frets: 13
    What actually happened to it? :)
  • munckeemunckee Frets: 12483
    You ain't no hippy man : )
  • The owner as I far as I was told when I bought it had a Hendrix moment on stage, walked off and chucked the band he was in!!!
  • ZenOvertoneZenOvertone Frets: 234
    Has the neck been plugged with dowels?
  • No the neck was fine....NOW SOLD
