The MIDI out on the M5 is apparently not very reliable as a MIDI thru- that is, it will send MIDI messages generated by the M5 itself, but may not pass on messages it receives via the MIDI in. I haven't tried this with MIDI clock, but it may be that you need a separate MIDI thru box to split the signal from the Timeline to the M5 and the H9 individually. Good news is they're not that expensive.
It sounds like neither the H9 or M5 are reliable at passing midi thru so I might need the box
https://www.strymon.net/faq/will-the-timeline-send-midi-time-or-midi-beat-clock/
H9 can though, so can the M5, so it's just a case of using one of those to generate the clock signal instead.
The Timeline is the one I want to send TT from
