What are everyone's favourite Single Coils?
Hey guys, i am getting to the final stages of a hand built strat i am working on and that means choosing pickups. Simply wondering what everyone would recommend as i have always been a humbucker person. Not looking for high output, Been looking at lace sensor golds which i have heard good things about but just wondering what everyone would recommend.
Thanks in advance all
  • LebarqueLebarque Frets: 3903
    Tried plenty. Rocketfire Total 60's remain in my strat.
    edited April 2018
    Recently listened to a lot of demos to compare as I was thinking about replacing my Strat pickups with non-staggered pole piece pickups and I settled on the Bare Knuckle Apaches as being the best sounding to me (ended up just sticking with the staggered ones I have).
    Note: I don't have experience with them myself, I just preferred the sound from demos.
    Edit: The ones I stuck with are Fender CS Fat 50s which I really like the sound of too, albeit different sounding to the Apaches.
  • robinbowesrobinbowes Frets: 3054
    I've got Kinman pickups on all my Fender instruments. Impersonator '54 on my strat, AVn Blues set in my 12-string, and a Broadcaster set in my Tele.
    R.
  • FunkfingersFunkfingers Frets: 14572
    Been looking at lace sensor golds ... just wondering what everyone would recommend.
    If you are hooked on the idea of Lace Sensors, I suggest their Holy Grail series. The polepiece configuration is an important factor in the Stratocaster sound. The regular Sensors hold up well under extreme gain but fall short on *quack* and *ping*.
    Beyond that, any recommendation would need to be based on hearing the unamplified guitar.
  • HAL9000HAL9000 Frets: 9737
    Haven’t got a lot of experience in this type of thing, but am very pleased with the OilCity StoneTones in my Strat. After discussing my requirements, OilCity recommended (and fitted) a baseplate to the bridge pickup in my set. Something worth considering as bridge pickups in Strats can often sound a bit thin, and a baseplate just gives it that extra kick.
  • TheMarlinTheMarlin Frets: 7934
    Gretsch Hilotrons or Mojo Goldfoils.
  • KebabkidKebabkid Frets: 3334
    Fralin Blues Specials with baseplate.
    Clear, defined with all the quack and spank on cleans but they work wonderfully well through different gain structures
  • Fender’s CS69s. Low-is output, but they still sound fat and hairy. Pair with a bass-cut pot on the guitar and they’ll sound good into any amp. I l-o-v-e mine.
  • paulnb57paulnb57 Frets: 3073
    Tried a few in my Original 50's Strat and settled on Fat 50’s in the neck and middle with a BK Sinner with backplate at the bridge, In another Strat I have Mojo 60's, also very nice.....
  • downbytheriverdownbytheriver Frets: 1055
    edited April 2018
    Creamery S90s - stunning sound. More stratty? Custom Shop 69s. Off the wall but a Custom Shop staple from a while back? CS 69 in the neck, Fat Fifties RWRP in the middle and Texas Special in the bridge.
    Prepare to spend much money in the search for the grail...
    Wisdom!
  • munckeemunckee Frets: 12422
    The best strat pickups I have heard are custom shop 57/62's as found in classic player 50s strats, very low output but lovely sound.
  • octatonicoctatonic Frets: 33839
    Suhr ML's do it for me.
  • westwest Frets: 996
    V60lp's or lollar blackface .....  would like to try the ml's one day ....
    @west I've got a set of Suhr FL's (old name for ML's) kicking around somewhere if you fancy them?
  • CloudNineCloudNine Frets: 4284
    Likewise. It's very hard to imagine better Strat pickups.
    cheers Lbq ;) im ok at the mo' thanks , im pretty happy with the v60lp lollar imperial bridge and suhr ssc , im needing to get me humbucking requirments sorted out with a collings soco lc or i35lc its taking ages to find the right one s/h  ...  i will give you a shout if anything changes ;)
  • p90foolp90fool Frets: 31659
    Or prepare to not bother. Most properly made vintage output Strat pickups are much of a muchness - a hair more bottom end here, a touch less mids there.
    The trick is in balancing outputs between your pickups and having a decent bridge and trem block.
    Then you'll find it might not work well with the rest of your entirely humbucker based rig, so you'll need the odd tweak to pedals or whatever there.
    Spending £150 a time on half a dozen sets of inseperable pickups will not get you there, learning how to play a Strat will.
    There is a great deal of sense contained within this
    edited April 2018
    @CloudNine ;  Aha, another fan! Quite rare this side of the pond I believe. I've never seen a decent demo of them, so they remain fairly low-key.
