If you had two indentical Les Pauls....
HootsmonHootsmon Frets: 15991
edited April 2018 in Guitar
and you were happy with the burstbucker pick ups in both guitars but you wanted to swap a set of PUPs out for an after market set of HBs, what set of HBs would you choose that would set the guitar apart from the other one?
tae be or not tae be
  • FunkfingersFunkfingers Frets: 14573
    Depends on;
    • Which exact versions of Gibson Burstbucker are currently in use?
    • What sort of sounds the guitar is expected to produce?
    • Budget.
    Seymour Duncan Antiquity pickups are nice but pricey. The Saturday Night Special and Whole Lotta Humbucker pairs are both interesting in their own way. An open bobbins SHPG-1N Pearly Gates or an SH-1N '59 with an Alnico 4 bar magnet and the metal cover would do me nicely for the neck position.
  • chris45chris45 Frets: 221
    http://thefretboard.co.uk/discussion/94963/gibson-mhs-pickups
    I have these in a 349 and love them.  As in the above thread they aren’t available as separates but they give a very big difference over my burstbucker LP (even discounting the body difference).  Low output!
  • jimmyguitarjimmyguitar Frets: 2474
    I’d put a set of Peter Green spec PAFs in it for the ‘out-of-phase’ middle sound or some humbucker sized P90’s?
  • HootsmonHootsmon Frets: 15991
    Depends on;
    • Budget.
    I guess the latest set of BB
    looking for rock and roll but different character to the BB....sort of a thing
    no matter
  • UnclePsychosisUnclePsychosis Frets: 12959
    Gold Foils.
    Preferably single coil ones.
    There have always been three variants. BB1 = underwound, BB2 = "regular" and BB3 = overwound. The more recent versions gain the suffix Pro and a magnet change from Alnico 2 to Alnico 5. (Big clue, there!)
    Magnet swapping should do that. A4 for the neck position and Un-Oriented Alnico 5 for the bridge position.
  • JerkMoansJerkMoans Frets: 8797
    I - all too briefly - had a set of OX4 Hot Duanes in an @Elwood loan concept gold top, and they were rather raunchy.
    Inactivist Lefty Lawyer
  • DefaultMDefaultM Frets: 7373
    Make your own out of Lego.
  • SunDevilSunDevil Frets: 511
    edited April 2018
    If you like the tone and just want ‘different’ then a magnet swap is the way to go.
    Unsolder the covers (aka ‘the tricky bit’) and then try going up from the Al II mags you have. When you’re happy, you’re you can choose to re-solder the covers.
    If you flip the magnet by accident, so much the better..
    For the price of a set of Duncan’s, you can by 2 of every magnet going
  • p90foolp90fool Frets: 31663
    If you're happy with both guitars but they're too similar, sell one and buy something totally different, or just go on holiday.
  • hotpickupshotpickups Frets: 1822
    I've put a pair of monty's Humdingers in my les Paul. Sound great
  • breezytelebreezytele Frets: 273
    I’ve put humbucker sized p90s (Montys again) in an SG.
    He uses a p90 bobbin but just trims the ends of the plastic to fit under the cover
    The result  is so good I’m thinking of repeating that with a les Paul.
  • adamm82adamm82 Frets: 448
    I quite like the Seymour duncan slash pickups in my les paul.  hmm i need another les Paul.
