hi there all
im new to this site and thought id share a pic of my newly created pedal board....im not an experienced player and certainly don't gig...I have collected these some old/new over the last year or so and just like making cool sounds !.......please comment with any advice/comments/tips/criticisms its all welcome !
if the photo link doesn't work then shout...as was not sure how to do it
attach https://farm1.staticflickr.com/866/27951995988_292d5d4dd5_z.jpg
cheers
You're welcome.
haha yes your quite right....it was a bit rushed since im trying to find the correct brackets for it to go under the pedal train...I have a Voodoo pedal power 2 mounted neatly underneath already....last resort will be Velcro ofc and then I can go shopping again :-)
it was my first dive into delay pedals and am very happy with it....has some call modes to try.. I really like the shimmer effect
thanks your help ill prob just keep the PSU where it is for the time being since I don't have any other pedal on my immediate shopping list...then do what you did and try to fudge a fixing underneath
if anyone out there suggests a pedal I must have that prob dosnt clash with the others then im all ears :-)
I was thinking about a pitch fork but looks a bit too technical for me ?
If you’re reasonably new to delays and modulation pedals, then you can try running these through the EL to make different sounds and tones. To make this easier you can use a patch box which are typically passive and you can find one that will fit on your board.
will def check out the Pitch Fork..cheers
