What amplifier are you using currently?
Does your amplifier have an effects loop?
You could use it like a regular drive pedal or tone shaping pedal going into the preamp, as suggested above.
But because it was designed as a preamp pedal, you could also bypass the amplifier preamp, and plug it straight into the power amp return and get some nice Fender cleans. Depends on what you want to do.
Or you can use it to go direct to PA.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Trading feedback here
