If you're soldering them for a Vero build do you use the little 5x2 Vero trick that the tagboardeffects guy suggests or do you just solder straight to the little pin?
EDIT: Cancel that, I just looked at them again, the Vero thing wouldn't work with those and they look like they have enough leg to solder to before the 90deg bend.
So much for not getting pinged on the slower options.
But how did PF calculate the duty? Based on what the value declared on the outside of the parcel?
The value of the goods for import VAT is based on the:
- basic value of goods, plus
- postage, packing and insurance, plus
- any import (Customs or Excise) duties charged
Mine was $201 inc P&P. Currently about £150. Import VAT is supposed to be around 20% and I was charged closer to 10% so I can only assume that the declared value was lower. Will confirm tomorrow. Either way, I can't complain. Although the parcel force admin charge of 11 quid is rubbish.
