Darkening a rosewood fretboard
Currently gathering bits and pieces together for a Jag build.
Wanted an ebony board on this but have picked up a nice Jag neck with a rosewood board.
So question is, can this be darkened to an ebony shade? obvious worry with stains is black fingers after playing!!
  • GagarynGagaryn Frets: 1553
  • CorvusCorvus Frets: 2942
    I have gone full black a couple of times, under strong light the wood colour can still show up. Don't really like to do more than darken a board up a few shades really, it's more realistic that way.
    Seal in with a thin coat of a drying oil, boiled linseed or Danish left to dry a couple of days. Stops the dye rub-off onto fingers. Redo it once in a while, the sealing oil can wear away and then the dye rub away as well.
  • WezVWezV Frets: 16782
    I have heard reports of the leather dye rubbing off onto fingers before.  it doesn’t have to at all, just depends on the surface it’s applied to.
    I think the issue is it’s intended to be used on raw wood, and does not take as well on a factory guitar that may have already had some kind of light oiling or conditioning.
    you can stain raw rosewood black, give a light rub down with 0000wire wool and never get black fingers at all.
     a coat of oil after won’t hurt at all though.
  • adampeteradampeter Frets: 775
    definitely only want to darken, not full black
    so leather dye is the way to go?
    Fiebings is good, I have Rustins other spirit-based wood dyes, no real difference between them, all are pigments & binders in solvent. I mix them to make colours without worrying what make but you won't go wrong with Fiebings.
