Splitting Virgin Media cable for Internet
Flink_PoydFlink_Poyd Frets: 2490
wifi signal on the PC is a bit patchy at times, drops out and have to keep reconnecting, just gets annoying after a while. Local shop has a splitter kit similar to this
2 Way Cable TV / Broadband Splitter Kit by electrosmart® https://www.amazon.co.uk/dp/B003ANFBPI/ref=cm_sw_r_cp_api_i_2cf8AbY1DQ4G7
Has anyone used one? Any signal loss or issues?
The Virgin feed comes through the front room where the pc is. The idea is to use  the old cable modem to connect the PC via ethernet, not bothered about the TV as it barely gets used nowadays.
Nobody is guaranteed tomorrow.....
  • boogiemanboogieman Frets: 12421
    edited May 2018
    Don’t know how yours is set up but our Virgin cable feed gets split through a little silver doodah just after it comes into the house. Looks very silimar to what you’ve shown. Main cable going in, two going out... one side to the router, one to the V6 box. It looks like it’d be easy to just extend one cable to either the tv box or router, AFAIK it’s just a regular co-ax cable with screw type satellite plugs on the ends.
  • Flink_PoydFlink_Poyd Frets: 2490
    edited May 2018
    That's how they're all setup. The main feed goes to a splitter for Internet and TV
    This is the idea. Main cable into new splitter for 2 outs not one. 1st out splits to PC for Internet via ethernet only in front room. second out is the original just into the middle room with existing tv and modem for wifi
  • SporkySporky Frets: 28674
    Not sure you can put two modems onto one cable.
    You might be better off putting the modem into modem mode and adding a more capable WiFi router.
  • SnagsSnags Frets: 5407
    Why not just run an Ethernet cable from the switch on the Virgin hub to the PC?
    Of even better, buy a decent router and put the hub in modem mode?
  • prowlaprowla Frets: 4942
    I don't think you can do two cable modems.
    However, if you're going to run cables, then you can just use an Ethernet to the 2nd location.
    Been down that route with the same results. Had an Asus RTN-66u running Merlin.
    Hub and PC are in different rooms, running CAT cable would cost about twice as much and mean more work, routing 15m odd of cable to the next room through all sorts of bends. Considered it before as well.
    Bugger, matey who used to work for Virgin says it doesnt work. Looks like CAT or powerlines, had them before in an other house with varying results.
  • wibblewibble Frets: 1110
    You need either a wifi extender - either on it's own or part of a powerline/homeplug solution. Or if going powerline, you also  ethernet into a powerline adapter.
    Alternatively, go for a wifi mesh solution eg Ubiquiti, Google wifi home etc
    How is running Cat5 more aggro than running coax?  (Says the person who categorically refuses to run Cat5 in his own house because it's too much aggo, but ... :) ).
    However, if cabling is out then either Open Mesh wifi, or similar, or powerline (Devolo, or the expensive TP-Link ones, IME - cheapo ones tend to fritz out or run alarmingly hot).
    Coax won't work anyway as confirmed by a mate who used to work for virgin. Walls are double brick, not cavity as it's an old house so wifi tends to be OK apart from that room. I'll figure some out
    Open Mesh butch ap off router, satellite ap in offending room.i
    Or power line ...
  • notanonnotanon Frets: 611
    Not considered the price of the solutions so far. You could use powerline ethernet kit and another WiFi access point. They have worked well for friends.
  • Emp_FabEmp_Fab Frets: 24429
    Before you charge down the route of wires and additional kit, establish if you actually do have poor signal strength near your PC.  If you have an Android phone, install the “WiFi Analyser” app (there are similar apps for IOS & Windows too) and tell me what RSSI (signal strength) you are getting near your PC for your WiFi network (‘SSID’).
  • marcus449marcus449 Frets: 151
    put the virgin box into modem mode and go for google wifi. no wires and the option to add more.
    It’s ok, don’t thank any of us or come back with an update...
    Ok I wont
