The guitar has always been stored in its case, in a dry, clean, non-smoking environment and handled extremely carefully.
Here is what Fender say:
To honour the 60th anniversary of the Stratocaster in 2014, the venerable American Standard Stratocaster now comes in a new limited edition model featuring Fender’s innovative channel-bound compound-radius fingerboard and the time-honoured look of a Dakota Red or Sonic Blue gloss finish.The fingerboard is inlaid into the neck in a design with an elegant appearance and a distinctive fretting-hand feel in which both edges are comfortably rounded, with no side seam between neck and fingerboard. Further, the fingerboard’s 9.5”-14” compound radius graduates smoothly from a more rounded profile at the nut (great for chording) to a more flattened profile near the body (great for soloing).
Specifications:
Series: Special Edition
Body Material: Alder
Body Finish: Gloss Urethane
Neck: Maple, Modern C Shape
Neck Finish: Hand-Rubbed Oil
Fingerboard: Channel-Bound Rosewood, 9.5"-14" Compound Radius
(241 mm-355.6 mm)
Frets: 21, Medium Jumbo
Position Inlays: White Dot
Scale Length: 25.5" (648 mm)
Nut (Material/Width): Synthetic Bone, 1.685" (42.8 mm)
Hardware: Nickel/Chrome
Bridge: 2-Point Synchronized Tremolo with Bent Steel Saddles
Tuning Machines: Fender® Deluxe Cast/Sealed Staggered
Pickups: Custom Shop Fat '50s Single-Coil Strat (Bridge, Middle, and Neck)
Pickup Switching: 5-Position Blade: Position 1. Bridge Pickup, Position 2. Bridge and
Middle Pickup, Position 3. Middle Pickup, Position 4. Middle and
Neck Pickup, Position 5. Neck Pickup
Controls: Master Volume, Tone 1. (Neck Pickup), Tone 2. No-Load Tone Control
(Middle and Bridge Pickups)
Control Knobs: Aged White Plastic
Pickguard: 3-Ply Parchment
Strings: Fender® USA 250L, NPS, (.009-.042 Gauges)
Other Features: Bent Steel Saddles with Elongated String Slots for Increased
Resonance and Sustain, Thinner Undercoat Finish for Improved Body
Resonance, Channel-Bound Compound Radius Fingerboard
Case: Hard Case is Included.
Here's a Video of this one...
