I have started experimenting with preamp tubes for my jcm 800 2204. I was looking for some advice on how to get a more classic rock jcm 800 as opposed to a high gain jcm 800 if you understand me. Valves I have to play with are:
Nos mullard
Sovtek 12ax7
Original Marshall ecc83
3 x electro harmonix
2 x nos Jan phillips 5751
I know everybody is different and the 5751s have a lower gain output but how would you set it up? Just now I have the mullard in v1 and the Jan phillips in v2 and v3. Btw when I have the Jan phillips in v1 and v2 and the mullard in v3 it's really low on volume!
V1 and V2 are the gain stages before the master volume, so if you are playing with the master volume turned down try swapping the valves around in those two positions first, for less drive you probably want the 5751 in V1, assuming it is working properly
Personally, I don't like 5751s, and I wouldn't put one in a Marshall at all.
For a proper classic JCM800 tone I would get three RFT 12AX7s. They are no longer as cheap as they used to be but they're the best-sounding in these amps - full and clear but also with plenty of gain and a good 'harmonic' richness.
But before you go any further... Marshall used RFTs (with Marshall labels) as stock in the later 70s and very early 80s - if you mean your Marshall valve is original to the amp it could well be one of these. If so, put it in V2, it will sound the best there and be the most reliable. I would put your Mullard in V1 and probably the Sovtek in V3.
No, I don't like 5751s - to me, they have a 'smooth', slightly metallic tone I dislike. (I hate smooth sounds...) They aren't bad in some Fender-type amps but I wouldn't put one in a Marshall.
Preamp gain on 10 is *always* the right setting for a 2204
Btw 2 on the master kinda drowns out my drummer haha. It's the loudest jcm 800 iv heard! I would say it's similar to my 100w jcm 900 on 5!
They are. They're some of the loudest 50W amps ever made - much louder relative to their rated power than 900s.
If you even get the chance, try it with the preamp on 10 and the master on 6
I actually like the 2203/4 best - I also think the MV set below halfway is fine, if you can't get away with more volume. I once did some work on a very early '76 (small logo/toggle switch) 2203 which I think is the best Marshall I've ever heard - just the absolute definition of rock guitar sound.
Power valves still make a difference even when the power section is clean, just not as much. I actually like EH EL34s, but they don't last very long... they sound similar to the old RFT 'Siemens' EL34s which Marshall also used as stock at the time.
