Damage caused by guitar techs
12346»
  • prlgmnrprlgmnr Frets: 3992
    prlgmnr said:
    This isn't doing much to help cure me of my current method of dealing with a guitar needing a setup, namely just buying a new guitar.
    That's my approach to restringing.
    I recall Carol Kaye saying in an interview that she was so busy with studio work in the 70s that she had to buy a new bass every time she needed fresh strings.
  • impmannimpmann Frets: 12677
    No disrepect to Ms Kaye... but based on her dull, thuddy sound that probably means she bought one new bass in 10 years...
  • GSPBASSESGSPBASSES Frets: 2351
    That's a bit harsh, after all, a session musician who's been on at least 10,000 recordings somebody must like her sound and the way she plays.
    edited May 2018
    This thread is scaring me to death, as I have two guitars that need some work!  o
  • BrizeBrize Frets: 5635
    Freebird said:
    This thread is scaring me to death! I have two guitars that need some work  :o
    Are they relics? If not, they probably will be. ;)
  • paulphoenixpaulphoenix Frets: 141
    A local tech took it upon himself to 0000 wire wool the neck on my Charvel So-Cal without asking me, as he thought it would play better without the finish on the back of the neck.....he fucked up the set up too (which is why I took it there in the first place).
    I haven't been back.
     Another local tech called me anal when I took back a guitar for adjustments to a new nut he installed that I was not happy with - and he did an ugly job on my stainless steel refret too.
    I do my own set ups now....
  • StuartMac290StuartMac290 Frets: 1474
    edited May 2018
    Actually, that's pretty much my approach to buying cars - I've never changed the wiper blades on a car.
    What annoys me the most is when I do work on one of mine, slip up and ding it, and then don't tell myself for weeks - only to then open up the case and find it dinged some weeks later.. I get so furious with myself.
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
    I'm not saying I didn't like what she did or the sound she made - but based on that uber-damped clicky, thuddy sound that she pioneered (and still uses - complete with lump of foam rammed under the strings), would you say that fresh strings would make much difference to that sound?
    Hence the attempt at humour...
  • Jimbro66Jimbro66 Frets: 2431
    Lots of grim stories here.
    My own contribution is the time I took a guitar with slightly sharp fret ends to a recommended tech and asked him to smooth them. He certainly smoothed them but he filed them at a very shallow angle so that the chamfer was about 4-5mm long at each fret end. The inevitable consequence was that the high and low E strings could easily slip off the fret ends, not to mention the buzzes when bending strings. The only solution was to get an expensive refret done elsewhere as my confidence in him was by then zero.
  • John_AJohn_A Frets: 3775
    Currently have a guitar in with Nigel Roberts for some major work, he's been great to deal with but havent seen the results yet :)
    If possible would really appreciate if you could let me know how that goes.
    Good news, guitar is back from Nige and playing like a dream, quick, cheap and very good!  He's my man from now on :)
  • BoromedicBoromedic Frets: 4882
    Cool, glad to hear it mate. I knew it would all be grand for you, but I'm pleased you have found yer man!
    My head said brake, but my heart cried never.
  • HalikusHalikus Frets: 59
    Reading this it seems like the wild west out there,  on a serious note surely if a tech damages an instrument or just plain bad work you'd be well within reason to get the guitar sorted elsewhere then invoice the original tech for the cost of repairs?
  • TeyeplayerTeyeplayer Frets: 3270
    Thanks for that, he’s going straight to the top of the list for the next big job.
    I think it's a combination of genuine accidents (of which there will be some with tools in the proximity of guitars) and arrogant or thoughtless techs who think that it's fine to modify other people's guitars without their permission.
    The solution isn't rocket science: (i) own up to accidental damage and put it right, and (ii) don't do anything to a guitar unless it's been expressly agreed with the owner.
  • mbembe Frets: 1840
    Stop setting up your guitars in a trance man.
    You can’t beat spannering your guitars with a bit of Armin van Buuren in the background..
  • mburekengemburekenge Frets: 1060
    Thanks for this thread. Picking up two that are getting worked on today. Now I'm nervous
    Great success!
    Ccgx and Gray Guitars both dud good work
